Author Topic: What profile are the keycaps on Leopold FC750?  (Read 15475 times)
Offline fuzzybaffy
« on: Tue, 13 October 2015, 03:33:16 »
So I'm thinking of purchasing a Leopold FC750, with the PBT caps.
On the pictures, however, they seem a little bit lower height than regular OEM keycaps. Does that mean they are Cherry profile? Or are the keycaps indeed OEM profile, but just look like Cherry profile because of their shape?
Re: What profile are the keycaps on Leopold FC750?
« Reply #1 on: Tue, 13 October 2015, 06:26:15 »
They should be Leopold's own low profile they have a fancy name for it that escapes me at the moment, very similar to cherry profile.
Offline bocahgundul
  • a seal
« Reply #2 on: Tue, 13 October 2015, 06:42:36 »
Its cherry profile right?
Offline Jokrik
« Reply #3 on: Tue, 13 October 2015, 07:31:33 »
This
you can see my comparison here:
https://geekhack.org/index.php?topic=70856.0
Offline fuzzybaffy
« Reply #4 on: Tue, 13 October 2015, 08:19:48 »
Yikes. That's a big difference. Looks like I'll have to get a set of OEM-sized caps if I purchase the Leopold, then.
Offline Hypersphere
« Reply #5 on: Tue, 13 October 2015, 08:49:44 »
Yes, Leopold has its own profile. They make some elegant keycaps, but I have found the profile too low for my needs. I need OEM profile, which is higher than Leopold or Cherry profile.
Offline fuzzybaffy
« Reply #6 on: Tue, 13 October 2015, 09:41:56 »
Slight OT, but are all Ducky keycaps, even the sets sold separately, all OEM-size? Or are there some types that are Cherry-sized?
« Reply #7 on: Tue, 13 October 2015, 10:06:07 »
Unless they've changed recently all Ducky caps should be OEM profile.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #8 on: Wed, 14 October 2015, 00:07:11 »
Step Sculpture 2 Profile.  And yes Asians doesn't make any sense when they try to name things.
=_____=
Offline Jokrik
« Reply #9 on: Wed, 14 October 2015, 09:12:35 »
=_____=
We make things simpler, by not making senses
