Author Topic: Customizing/drawing on blank keycaps  (Read 4484 times)
Offline Terbografx
« on: Fri, 16 October 2015, 04:10:57 »
I think it would be fun to draw or paint on blank keycaps. Have any of you ever tried this? What would be the optimal type of ink to handle all that typing mileage?
Offline Luca_Scorpion
Re: Customizing/drawing on blank keycaps
« Reply #1 on: Fri, 16 October 2015, 10:44:37 »
I was thinking kinda the same thing, painting over transparent keycaps so the backlight gets colored nicely.
Might try it somewhere in the near future, but I would like to hear what people have to say about types of paint etc.
« Reply #2 on: Fri, 16 October 2015, 13:14:44 »
Done quite often by the most skilled of skilled,
https://geekhack.org/index.php?topic=75517.0
Offline Giorgio
« Reply #3 on: Sun, 18 October 2015, 16:52:11 »
And painting a key cap with a transparent paint and then applying  a dye color?
