Author Topic: Hello!  (Read 1781 times)
Offline meevilsheep
Hello!
« on: Fri, 16 October 2015, 12:11:25 »
Hello guys..
My name is evilsheep, and i'm a mechaholic..
Currently own the K95 RGB, QFR Rapid-I (both MX Brown) and another chinese TKL board with Blue Outemu switches.
As for caps... NKPC rainbow caps in the mail, pre-ordered a Carbon Black set.. 1 warmaster on the way (thanks to Evo_Spec) and looking for more..
That's about it  :)
Offline jerue
  • (Whenever that happens :P)
Re: Hello!
« Reply #1 on: Fri, 16 October 2015, 13:17:34 »
Welcome!
How do you like the Outemu switches? I have not heard too much about them.
Offline meevilsheep
Re: Hello!
« Reply #2 on: Sat, 17 October 2015, 16:30:30 »
Welcome!
I've not yet tried them. That keyboard it's on route right now. Will try to make a review when i get it.
Re: Hello!
« Reply #3 on: Sun, 18 October 2015, 03:20:36 »
Welcome to Geekhack!
Are the Outemu switches MX-compatible?  That would be another one to add to the list of MX_compatible switches.
A review would be great - you've seen the reviews section?  Best place for a review thread ;)
