Author Topic: Soldering surface mount diodes  (Read 1256 times)
Offline trenzafeeds
  • **** off
« on: Fri, 16 October 2015, 16:08:32 »
This is my first time soldering surface mounts. I know they look like ****, but will these at least be functional?
demik will never leave.
Unless he gets banned.
Offline BlueNalgene
Re: Soldering surface mount diodes
« Reply #1 on: Fri, 16 October 2015, 16:14:10 »
Really hard to tell from that pic.
I recommend using an magnifying glass (or a loupe if you have one) to inspect the pads.  If metal+metal connection is shiny, it should be good enough.
