Author Topic: GMK Switch Tester With QMX Clips  (Read 3572 times)
Offline RoastPotatoes
    • RoastPotatoes Keyboard Blog
« on: Fri, 16 October 2015, 17:46:39 »
https://www.massdrop.com/buy/gmk-switch-tester?mode=guest_open
I wasn't sure if these were available to purchase so I think this counts as a good find.
I have one of the switch testers and they are really nice. The Q's were my first experience with GMK doubleshot and they are really nice.
Offline alienman82
Re: GMK Switch Tester With QMX Clips
« Reply #1 on: Fri, 16 October 2015, 20:10:10 »
removed.
« Last Edit: Thu, 01 March 2018, 17:11:12 by alienman82 »
« Reply #2 on: Fri, 16 October 2015, 20:10:56 »
If they had a plate mounted version...
The q clips don't work with a plate though.
Offline alienman82
« Reply #3 on: Fri, 16 October 2015, 20:11:24 »
removed.
« Last Edit: Thu, 01 March 2018, 17:11:10 by alienman82 »
Offline Jokrik
« Reply #4 on: Fri, 16 October 2015, 20:20:40 »
I assume that the clip would interfere with the plate, so if we shave it off it might fit well?
but to shave that amount of clip....
« Reply #5 on: Fri, 16 October 2015, 20:20:43 »
exactly my point
I can't read but I agree! :P
Maybe just integrate it into the switch top housing.
« Reply #6 on: Fri, 16 October 2015, 20:37:10 »
Thanks for the heads up!
Offline alienman82
« Reply #7 on: Fri, 16 October 2015, 20:41:55 »
removed.
« Last Edit: Thu, 01 March 2018, 17:10:58 by alienman82 »
Offline asgeirtj
« Reply #8 on: Sat, 17 October 2015, 06:19:24 »
does this tool dampen the bottom up sound?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline Oobly
« Reply #9 on: Tue, 20 October 2015, 04:10:08 »
Problem is the clip grips where the plate goes, so if you shave it down it won't stay on any more. I think they're a nice idea, poor implementation. What I mean is that the kind of person who'd buy them would more than likely have a plate mounted board.
Not to mention they only work well with Cherry profile keycaps that have low crossbars. DCS, DSA, SA and some OEM profiles, for instance, would bottom out just as hard as without them. Poor implementation.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
