Author Topic: HP D4950  (Read 5993 times)
Offline Rhedone
HP D4950
« on: Sun, 18 October 2015, 06:36:24 »
I've come across this keyboard in a nook at my work.
But i've been able to find very little about it online.
I was wondering whether anyone could enlighten me about it
Re: HP D4950
« Reply #1 on: Sun, 18 October 2015, 21:02:03 »
An HP D4950BR is a fairly standard membrane NetServer keyboard.  NetServer was HP's line of x86 servers, so I'm guessing it's just a standard membrane PC keyboard.
Offline SamirD
Re: HP D4950
« Reply #2 on: Mon, 19 October 2015, 22:10:44 »
How does it feel?  Can you post a full shot of the underside of it?  It has some signs of being a keytronic design.
The FCCID also indicates Keytronic.  If I can see the underside, I can be reasonably certain it's a keytronic.
Offline Rhedone
Re: HP D4950
« Reply #3 on: Tue, 20 October 2015, 02:58:41 »
I can't plug it into the pc it has what looks to be a din connector.
I'm currently tracking down the owner or the director of the department that bought it to let have/buy it.
I'll post more pics if my quest succeeds.
Offline SamirD
Re: HP D4950
« Reply #4 on: Tue, 20 October 2015, 10:21:06 »
That should be a ps2 connector.  You can use a simple ps2-usb adapter to connect it to any modern day system.
After looking at the missing keycap on the bottom photo, I'm almost 100% that's a keytronic--the leds, the blank panel, the raised bezel, the look of the area with the missing switch.  If I could only see the feet and the rest of the bottom, I would be 100%.
Offline Rhedone
Re: HP D4950
« Reply #5 on: Tue, 24 November 2015, 14:47:39 »
Alright i got one of em home after tracking down the manager who owns the damn things and getting his approval, haaa the delightful bureaucracy of big companies. Got only one even though they arent using any but lets not get greedy.
Anyhow what i wanted to comment is that this thing feels pretty damn tactile for a membrane keyboard. Once i get a PS2 to USB converter i'll plug it in and give it a more thorough feel. Can anyone explain this or am i just overstating it?
I have added the pic SamirD asked for + a part of my foot for good measure it seems.
Also i cant believe i didnt recognise the PS2 connecter all that nerd-cred gone  :D
118248-0
« Last Edit: Tue, 24 November 2015, 14:59:57 by Rhedone »
Offline Homenubbie
Re: HP D4950
« Reply #6 on: Tue, 24 November 2015, 15:21:42 »
Older rubber dome keyboards often feel better than the cheap ones from China today.
Re: HP D4950
« Reply #7 on: Wed, 25 November 2015, 03:44:37 »
If you're looking for a PS/2 to USB adaptor, I can recommend these: http://techkeys.us/collections/accessories/products/usb-to-ps2-serial-multimode-adapter
I've had good results getting all sorts of old keyboards working on a Mac, so I reckon they'd work with most keyboards.
Offline Rhedone
Re: HP D4950
« Reply #8 on: Wed, 25 November 2015, 06:18:37 »
Thanks Rowdy i was looking for one of those.
I do live in Belgium so lets see if i can find one that ships from Europe.
Re: HP D4950
« Reply #9 on: Wed, 25 November 2015, 23:23:58 »
There's quite a few around, different ones I mean, and from different outlets.
I think I got mine from Geekhackers.org, although AFAIK they are currently on hiatus.
Offline SamirD
Re: HP D4950
« Reply #10 on: Fri, 27 November 2015, 14:46:41 »
Those feet are typical Keytronic design.  :thumb: Even though it's a rubber dome, it will feel like a really, really nice rubber dome.  Congrats on the score!  Enjoy it once you get that ps2-usb converter.
Offline Rhedone
Re: HP D4950
« Reply #11 on: Sat, 28 November 2015, 03:33:46 »
Woohoo i found a thing  ;) thanks for the info i'll be giving it a go once i get the converter and clean it, its dirty as hell.
Offline SamirD
Re: HP D4950
« Reply #12 on: Sun, 29 November 2015, 23:41:52 »
Definitely post back and tell us what it's like!
