Author Topic: Affirmative (Unicomp) Model M-122 (p/n AC40956), $30.00 OBO + shipping  (Read 9379 times)
Offline ander
  • I type, therefore I am
Unicomp Model M 122 Key Mechanical Keyboard (eBay)
$30.00 or Make Offer + $17.90 shipping (U.S.)
114178-0
These rebranded Unicomps are really neat. It's what you'd expect to pay for an IBM/Lexmark-made 122—but unlike those, this can be can be connected directly to a PC without a converter. (Maybe someone can explain why?)
« Last Edit: Sun, 18 October 2015, 17:18:40 by ander »
Re: Affirmative (Unicomp) Model M-122 (p/n AC40956), $30.00 OBO + shipping
« Reply #1 on: Sun, 18 October 2015, 17:17:45 »
https://geekhack.org/index.php?topic=64335.0
Those can also be found there.
Offline ander
« Reply #2 on: Sun, 18 October 2015, 17:19:57 »
Aha, I thought ComradSniper's carpeting looked familiar! Well, I hope he appreciates the plug. This is a very good deal for a directly-connectable BS 122.
« Last Edit: Sun, 18 October 2015, 17:26:17 by ander »
« Reply #3 on: Sun, 18 October 2015, 20:48:08 »
What controller would these have in them?  Would it be a drop-in replacement for the controller in an IBM M122?
Offline ander
« Reply #4 on: Mon, 19 October 2015, 05:22:48 »
Nope, as M-122 controllers can't connect to PS/2. They're designed to connect to "dumb" terminals, which were input/output devices for mainframes rather than stand-alone computers.
Someone feel free to correct me on this—but I think these later Unicomp-made, PS/2 122's started appearing because PCs eventually replaced most terminals.
In addition to everything else PCs can do, they can run terminal-emulation software and appear as just about anything to a bigger system. And when PCs became so popular and were produced in such high numbers, I imagine they were actually cheaper and more easily obtained than specialized terminals. With a multitasking OS, you could use a PC to emulate a terminal and do other stuff with the data you were accessing (and, of course, play Solitaire when the boss wasn't around).
So I'm guessing that's why 122-key, PC-compatible boards like this one became the new "terminal" boards.
Offline njbair
    • nickbair.net
« Reply #5 on: Mon, 19 October 2015, 07:09:35 »
I think what rowdy is asking is, can you take the PS/2 controller out of one of these boards and put it into a terminal Model M-122?
I don't know the answer, I guess it would depend on whether the ribbon connectors are the same inside. If so,I don't see why not.
I actually have two of these Affirmative boards that I bought from CS when he first listed them here on Geekhack. I converted one of them to ANSI using some leftover Model M caps. The other one I'm in the process of chopping down into an unsaver-ish board but without the nav cluster. I doubt I'm going to be able to keep the stock controller though.
I'll have to pop open my terminal Model M and take a look at the controller to see if they're comlatible with the Unicomp.
My boards:
« Reply #6 on: Mon, 19 October 2015, 14:20:07 »
Yes, this :)
Offline 0100010
  • Not Sure
« Reply #7 on: Mon, 19 October 2015, 19:32:06 »
Yes, this :)
These Unicomps don't use the same near center mounted FPC connector type controller that IBM or Lexmark M's do.  So, the short answer is, no.
EDIT : This thread has some pics - https://geekhack.org/index.php?topic=62060.0
« Reply #8 on: Tue, 20 October 2015, 02:23:55 »
Yes, this :)
my recommendation would be to take the controller out of a RD 122 key and use the controller from that.
I think I have a spare around here somewhere.
Then again you could also grab an arduino pro micro fro $6 and use that instead.
You could swap the controller and membrane (and other parts of the guts), but why put so much work into one of these?
« Last Edit: Tue, 20 October 2015, 02:31:04 by dorkvader »
« Reply #9 on: Tue, 20 October 2015, 04:51:44 »
Yes, this :)
If that was directed at me, I like Model M keyboards, and kinda like the large size of the M122 as a contrast to my TKL keyboards and HHKB.
I've acquired a Model M 122 at a very reasonable cost, but it is missing most of the keycaps, has the standard terminal DIN connector, and is the ISO-like layout.
My ultimate plan (long term, as I am short in time and money at the moment) is to convert it to ANSI, bolt mod it, install some sort of convertor in it, and get a keycap set, preferably pearl and pebble.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #10 on: Tue, 20 October 2015, 23:35:18 »
Yes, this :)
Colossus controller.
Go down to the bottom of the page and select which M122 you have.
http://phosphorglow.net/store/products/universal-model-m-usb-controller/
End result:
« Last Edit: Tue, 20 October 2015, 23:37:14 by Snowdog993 »
« Reply #11 on: Tue, 20 October 2015, 23:55:33 »
End result:
Wow!
Yellow plate too :D
That would be perfect and is what I'm aiming at (except for the yellow plate - my skillz do not extend that far).
Gotta start saving ...
Offline njbair
    • nickbair.net
« Reply #12 on: Wed, 21 October 2015, 00:01:20 »
End result:
Wow!
Yellow plate too :D
That's not a yellow plate. It's just a mylar sheet that slips over the existing barrel plate. He offers them in tons of colors.
My boards:
Offline Snowdog993
« Reply #13 on: Wed, 21 October 2015, 00:06:20 »
End result:
Wow!
Yellow plate too :D
Correct.  It is a mylar underlay.
http://phosphorglow.net/store/products/colored-underlay/
« Reply #14 on: Wed, 21 October 2015, 04:39:08 »
Even nicer! :)
And more off topic in this thread ... so I have bumped my Model M refurbishment thread.
Offline ander
« Reply #15 on: Wed, 21 October 2015, 06:08:02 »
Geez, sorry I misinterpreted Rowdy's question and wandered off into computing history... I think I was trying to do too many things at once, and hadn't reserved enough brainpower here.
