Author Topic: Does Alumunium case made a difference in typing feel?  (Read 2297 times)
Offline bocahgundul
  • a seal
« on: Tue, 20 October 2015, 06:17:40 »
For a cherry mx clear not cherry mx black.
Offline Bucake
Re: Does Alumunium case made a difference in typing feel?
« Reply #1 on: Tue, 20 October 2015, 06:19:57 »
yep
Offline bocahgundul
  • a seal
Offline bocahgundul
  • a seal
« Reply #3 on: Tue, 20 October 2015, 06:56:14 »
Anyone?
Offline Oobly
« Reply #4 on: Tue, 20 October 2015, 06:58:16 »
Definitely. It takes away that "hollow" feeling you get with plastic cases. More solid = more awesome. Sort of makes each key feel independent and consistent. Let's you feel what the switch is doing a little more. Unfortunately, with stock Clears this means you can feel the "roughness" of the slider, so it can create a desire for more mods / better switches :) That's when you buy some Zealios and start to experiment with keycaps... then your wallet cries, but what's money but a tool for use in reaching typing Zen.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline bocahgundul
  • a seal
« Reply #5 on: Tue, 20 October 2015, 07:01:15 »
So its the best for mx black? I don't know what to buy Kul es 87 or pok3r with cnc case.
Offline heedpantsnow
  • Old enough to know better
« Reply #6 on: Tue, 20 October 2015, 10:55:51 »
I think among metal cases there's a big difference between the ones with support "ridges" vs. the ones with just standoffs.
I also think a plate makes a bigger difference.  I'd rather have a plastic case + quality rubber feet + quality plate than a metal case with no plate. That's just me though.
I'm back.
