Author Topic: HELP: Pok3r stuck in Layer 2/Keys not responding  (Read 8110 times)
Offline Terbografx
« on: Wed, 21 October 2015, 02:27:12 »
I tried putting my Pok3r in Layer 2 for the first time (Had this keyboard for about a month). Now none of the keys work. Can't factory reset, and the LED is still on. I also tried unplugging it, then inserting it into another USB port.
Offline swimmingbird
  • keyset hoarder
Re: HELP: Pok3r stuck in Layer 2/Keys not responding
« Reply #1 on: Wed, 21 October 2015, 04:00:40 »
You've tried the whole holding down both alt keys?
Offline Terbografx
« Reply #2 on: Wed, 21 October 2015, 04:13:46 »
Just tried it.
Nothing. :(
Offline Coreda
« Reply #3 on: Wed, 21 October 2015, 04:16:10 »
I'm assuming you've tried the FN+Shift and FN+Space toggles?
Offline Terbografx
« Reply #4 on: Wed, 21 October 2015, 04:20:48 »
I have not. Just tried what was in the manual. Might as well try it now.
Thanks for all the suggestions, everyone, btw.
Update: Still nothing.
« Last Edit: Wed, 21 October 2015, 04:22:44 by Terbografx »
  • keyset hoarder
« Reply #5 on: Wed, 21 October 2015, 04:54:41 »
Sounds like there is something wrong with it - I'd contact the reseller and see if they can give you a replacement unit
Offline Terbografx
« Reply #6 on: Wed, 21 October 2015, 10:08:55 »
Hmm..that's disappointing as I purchased it from Amazon (through Corus KB). Should I contact Corus as my return window is closed.
Edit: It seems the 4th dips witch was "on" I turned it off, and I was able to reset the keyboard.
« Last Edit: Wed, 21 October 2015, 10:13:36 by Terbografx »
Offline Terbografx
« Reply #7 on: Wed, 21 October 2015, 14:20:44 »
I'm assuming default/out-of-the-box Pok3rs have all the switches off?
  • keyset hoarder
« Reply #8 on: Wed, 21 October 2015, 14:58:21 »
Good to hear!
