Author Topic: Massdrop keyboard kits?  (Read 3811 times)
Offline profet
« on: Thu, 22 October 2015, 15:48:44 »
Where are the massdrop keyboard kits?
It's seems like forever between keyboard kit drops.
What is the hold up?
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Re: Massdrop keyboard kits?
« Reply #1 on: Thu, 22 October 2015, 15:52:08 »
Question unclear, go ask on massdrop maybe?
Probably the quickest way to get a keyboard kit up on massdrop is to run an IC here and make it really popular, then massdrop will see it and make one almost just like it but not quite as good.
« Reply #2 on: Thu, 22 October 2015, 15:57:14 »
Offline Pdub
« Reply #3 on: Sat, 24 October 2015, 15:40:54 »
Agreed. This is the quickest way, most likely.
Offline njbair
    • nickbair.net
« Reply #4 on: Sat, 24 October 2015, 16:06:50 »
I like how they always capitalize the C in "Community" like it's meaningful to them.
If they're going to do that they should end it with a circle R.
My boards:
Offline vivalarevolución
« Reply #5 on: Sat, 24 October 2015, 18:21:45 »
Massdrop seems to do the group buys for keyboard before they have a ready-to-go product.   Then they work out the kinks and finalize the product after they receive all the payments from everybody.  Or at least that's the way it seems to me.
Offline njbair
    • nickbair.net
« Reply #6 on: Sat, 24 October 2015, 18:30:21 »
Or you know, not at all...
My boards:
Offline Dernubenfrieken
« Reply #7 on: Sun, 25 October 2015, 10:06:10 »
Elementos was up, but got taken down because the child packs and pricing were ****ed up. Troubled minds should be going up soon, and I think there might be another set or two set to go up. Right now SP is really backed up, and GMK isn't much better.
Offline profet
« Reply #8 on: Sun, 25 October 2015, 10:38:29 »
Sorry... I mean kits... not keycap sets.
IE: Ergodox, Infinity, etc.
I would really like to build a third ergodox but sourcing my own parts came out to about $300 (the case being one of the most expensive parts). It would be nice to get a group buy even if its just to reduce the price of the case.
Switches + PCB + teensy + other electronic components are about $120 all together.
PMK blank keycaps add about $60 after shipping.
Case adds like $75-$100
I was under the assumption that the massdrop kit was like $200 with some fluctuation with options.
Offline ika
« Reply #9 on: Sun, 25 October 2015, 10:42:08 »
What cases are you looking at? I can't imagine shipping will be that expensive for this: http://falbatech.pl/prestashop/index.php?id_category=18&controller=category&id_lang=2
buy caps from classifieds, shouldn't be more than like $40.
Get the electronics from falbatech while you're at it, and get Gateron switches off Classifieds for $0.25/switch.
« Reply #10 on: Sun, 25 October 2015, 11:42:20 »
That's what I get for posting first thing in the morning
