Author Topic: New IBM Model F 122-key terminals on ebay  (Read 7319 times)
« on: Fri, 23 October 2015, 06:58:17 »
The price is high but not all that bad, and only once before have I ever seen a new one turn up. 3 available.
http://www.ebay.com/itm/ONE-MINT-IBM-TYPE-F-6110345-FL5-UNSAVER-CLICKY-KEYBOARD-3-AVAILABLE-P-/381446457014?
- D Trump 2026-10-24
Offline SamirD
Re: New IBM Model F 122-key terminals on ebay
« Reply #1 on: Fri, 23 October 2015, 10:20:36 »
Interesting.  It doesn't specify in the auction, but do you think these would just plug up to a PC or would they definitely need the converter?
Offline engicoder
« Reply #2 on: Fri, 23 October 2015, 10:53:29 »
Needs a converter
« Reply #3 on: Fri, 23 October 2015, 10:59:27 »
That's about the same price I paid on Taobao for the busted up one that you repaired for me. I put that new capsense controller in there, and it works great!
Offline joc
« Reply #4 on: Fri, 23 October 2015, 11:10:48 »
The F122 looks like it's in great condition although it's missing the keycap-top to the bottom left of the numeric Enter-key. Maybe they were used for a while and then stored away?
« Reply #5 on: Fri, 23 October 2015, 11:16:22 »
Excellent. Is that my dark gray Dupli-Color paint/dye job?
« Reply #6 on: Fri, 23 October 2015, 11:18:02 »
Yes, it is. It looks just a bit lighter in person, but the lighting in my room that day made it appear darker on camera.
It also looks like the label on one is peeled a bit on the bottom left corner...
Offline ander
  • I type, therefore I am
« Reply #7 on: Fri, 23 October 2015, 19:04:51 »
The price is high but not all that bad, and only once before have I ever seen a new one turn up. 3 available...
Yes, that's a reasonable price for what looks like an unused F-122... And gosh, how often do they turn up? I don't think I've ever seen one, actually.
These have a special 270-degree DIN connector (sort of like the large AT connector, but the pins are farther apart). You'd definitely need something like this to use it with a PC. You could also replace its internal controller with a Teensy, which has the advantages of being cheaper (only about $12 I think) and invisible. There are lots of posts about that here.
The F122 looks like it's in great condition although it's missing the keycap-top to the bottom left of the numeric Enter-key...
That's trivial.  Model M and F caps are interchangeable, and that particular one is just the standard " . Del" numpad key. You could use one from a Model M, or ask here on GH if anyone had an extra one they could spare.
It says they've been stored "their entire lives", so I'd take that to mean there was no wear on them at all. It certainly looks that way from the photos.
Quote from: jdcarpe
Again, that looks easily fixable. Also, remember, there are three of these, so you could just ask for one of the others instead—with the understanding that it was otherwise in the same perfect condition.
« Reply #8 on: Fri, 23 October 2015, 19:23:09 »
In about 4 years of watching ebay, I think that there was 1 other new one, about a year or 2 ago.
One of our Canadian friends found a stash of about half a dozen "excellent" (but not new) ones some time before that, but that is all that I can remember.
« Reply #9 on: Sat, 24 October 2015, 05:19:28 »
This is tempting *sigh*
But too expensive.  I'm still saving up to restore my M122.
Offline faycheung
  • Noob
« Reply #10 on: Sat, 24 October 2015, 05:31:29 »
I managed to snag the last one from of the Canadian guy. The keyboard is excellent, but the caps melted a little bit. Not sure if it was in that condition when he found it or when during shipping.
Offline SamirD
« Reply #11 on: Sat, 24 October 2015, 23:08:20 »
It would take A LOT to melt the keycaps coming from Canada--they've almost got snow now.  It must have happened before, but when?  How could storage get that hot?
Offline Bucake
« Reply #12 on: Mon, 26 October 2015, 06:23:29 »
ohhh my god. that is beautiful
( showoff )
Offline 1391406
« Reply #13 on: Mon, 26 October 2015, 20:29:45 »
$95 for a NEW 122-key Model F?! Yes, that's WAY more than reasonable. Look at the sold listings for 122-key Model F's and you'll see this is priced near the bottom compared to others that are practically dilapidated. I swear I'm really, really tempted, namely because these are so rare. I mean, come on. An unblemished case and internal mat that's likely in great condition! I'm astonished these haven't sold. How is this not a fantastic deal?
Offline faycheung
  • Noob
« Reply #14 on: Mon, 26 October 2015, 20:36:07 »
It was sent back in May or so, took about 3 months because of the huge string of typhoons travelling across the Pacific, so the keyboard must've been trapped in a hot sizzling container for a long long time (surface mail). Mind you they weren't completely melted or deformed, it's just that a small amount of thicker plastic seemed to have accumulated near the lower surface of each keycap.
« Reply #15 on: Mon, 26 October 2015, 20:54:26 »
I have dyed IBM M/F keycaps by boiling them for half an hour with no problem at all.
The case would be damaged before the key caps would.
Offline ander
« Reply #16 on: Sat, 31 October 2015, 07:17:02 »
In about 4 years of watching ebay, I think that there was 1 other new one, about a year or 2 ago...
And now two more have appeared—"new old stock", $125+shipping—which I posted about here. And they look really cherry.
Quote from: jdcarpe
That's about the same price I paid on Taobao for the busted up one that you repaired for me...
Quote from: Bucake
I'll second that!  :thumb:
Gee, maybe this makes up for the decidedly un-great "Great Deal" I had the misfortune to post recently.
Offline SamirD
« Reply #17 on: Sat, 31 October 2015, 11:51:21 »
Quote from: jdcarpe
Quote from: Bucake
I think that was still a good deal, keycap colors or not.  You said it yourself--new that's a $100 and you found it for $70.  That's a deal in my book.  :thumb:
