Author Topic: Keycap Holder(s)  (Read 26595 times)
Offline SamirD
Re: Keycap Holder(s)
« Reply #50 on: Tue, 10 November 2015, 23:37:00 »
Yeah, they seem to serve two different purposes very well--protected storage or display storage
Offline Glenmael
« Reply #51 on: Tue, 10 November 2015, 23:41:40 »
You got it!
I was going for the 'display' solution in this particular instance (had to add 2 more options to the IC though :()
Here's hoping we can get both!
« Reply #52 on: Wed, 11 November 2015, 00:02:45 »
Wait, I'm confused. Do the NPKC ones have some sort of cover? How can they stack if they don't?
Offline Glenmael
« Reply #53 on: Wed, 11 November 2015, 00:13:06 »
Negative, no cover, I'm planning on working with them (MD - hopefully) to get some additional supports put in so that they are stackable.
This will be the first time they will run these so I'm thinking we can have a little bit of say (if it does run that is)
Check out the [IC] for a running list of 'features' that would be nice to have.
Offline shibataken
« Reply #54 on: Wed, 11 November 2015, 09:45:16 »
Would be perfect if they were stackable, does something like that exist for those of us with limited space ie NYC apartments
http://elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=us104_case
You sir, are a god send.  Thanks for the link!
Offline mogo
« Reply #55 on: Wed, 11 November 2015, 11:27:17 »
Don't thank me just yet; as others have pointed out they've been out of stock for months. D:
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #56 on: Thu, 12 November 2015, 05:29:06 »
Looks awesome, if the price was like $20 and they came in either black or clear I would get two for sure :D
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline Glenmael
« Reply #57 on: Thu, 12 November 2015, 05:36:36 »
I'm hoping we get them way under 20 a piece :)
Offline dthai17
« Reply #58 on: Thu, 12 November 2015, 06:22:19 »
Been waiting for this for awhile now. I read some people bought some extra sets just to have the board with stems
Offline mrboovn
« Reply #59 on: Sat, 14 November 2015, 21:03:08 »
That's waht i have been waiting for while :D I am lazy replace keycaps whenever i want to take a picture for my new set
Offline Glenmael
« Reply #60 on: Sat, 14 November 2015, 22:39:34 »
Let's hope we can get it off the ground  :thumb:
« Reply #61 on: Tue, 17 November 2015, 16:22:26 »
Guys if you are ok ordering from taobao here is a link http://world.taobao.com/item/520154127936.htm?fromSite=main
Offline Glenmael
« Reply #62 on: Tue, 17 November 2015, 16:48:37 »
« Reply #63 on: Tue, 17 November 2015, 19:51:15 »
Guys if you are ok ordering from Massdrop here is a link https://www.massdrop.com/buy/npkc-keycap-holder?mode=guest_open
« Reply #64 on: Tue, 17 November 2015, 19:56:00 »
Offline Glenmael
« Reply #65 on: Tue, 17 November 2015, 21:31:44 »
Thanks mate. :thumb:
Surely they would have found there way through the IC :P
I hope the MD prices come down a notch  :-[
Offline SploogeFactory
  • Vitamin D deficient
« Reply #66 on: Sun, 22 November 2015, 00:32:24 »
Man, glad to see that this actually went ahead, nice work!
Methylated Spirits, not even once.
Offline mogo
« Reply #67 on: Mon, 23 November 2015, 15:43:36 »
I'm in for 3, thanks Glenmael!  :thumb:
Offline Glenmael
« Reply #68 on: Mon, 23 November 2015, 15:49:29 »
 :thumb:
Cheers fellas, embarrassingly enough I'm yet to jump on this...but will do so in the coming days. Prioritizing funds for GBs is hard  :-[
Offline Charizard
« Reply #69 on: Mon, 23 November 2015, 21:15:44 »
I'll definitely have to get in for a few of these. Glad to see it went through :)
