Author Topic: Compatible PCB's with ducky shine 3 tkl plate?  (Read 2011 times)
Offline humdar
« on: Mon, 26 October 2015, 23:10:44 »
I have a dead ducky shine 3 tkl pcb so i'd like to get a new pcb that would fit with the plate.
Preferably supports leds
Edit: TKL plate
« Last Edit: Tue, 27 October 2015, 19:04:54 by humdar »
Re: Compatible PCB's with ducky shine 3 plate?
« Reply #1 on: Tue, 27 October 2015, 04:04:12 »
The Winkeyless B.87 EX looks to be the right layout?
Edit: But looks for the mounting holes, you may be able to drill replacements and run some jumper wires but would be better if you didn't have to.  Assuming you want to use the case as well as the plate...
« Last Edit: Tue, 27 October 2015, 17:40:42 by suicidal_orange »
Offline humdar
« Reply #2 on: Tue, 27 October 2015, 19:04:34 »
Do you know if the a.87 and b.87 are the same in terms of spacing?
Because I actually have an a.87 but the function rows are closer and so it doesn't quite fit with the shine 3 plate
Re: Compatible PCB's with ducky shine 3 tkl plate?
« Reply #3 on: Tue, 27 October 2015, 19:40:50 »
You're right, I checked the spacing between Esc and F1 but not below.  Looks like the Ducky is 1/4 of a key while the B.87 is 1/2...
Gon NerD 108 looks to be right there but it has too big a gap between alphas and arrows and the Leeku mx3000 has an even bigger gap under the F row - I'm out of ideas.
You could always wire up a Teensy ++ like I did, though mine doesn't have backlighting :))
Offline humdar
« Reply #4 on: Tue, 27 October 2015, 21:27:15 »
Thanks, i think ill do that as a last resort and somehow try to get it backlit as well
« Last Edit: Tue, 27 October 2015, 21:48:00 by humdar »
