Author Topic: Poker 2 LED settings  (Read 2214 times)
Offline 1swt2gs
  • DOGE
« on: Tue, 27 October 2015, 01:14:42 »
Is the poker II suppose to remember your last known LED setting AFTER you unplug/plug?
I noticed when I unplug and replug in, the settings are at the dimmest one. IIRC, I read somewhere that it should remember it.
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline CG
Re: Poker 2 LED settings
« Reply #1 on: Tue, 27 October 2015, 04:11:45 »
Just tested mine and it remembers my led brightness setting.
Also on the online manual it does say the brightness level will be saved after power down.
Offline happyturtlee
« Reply #2 on: Tue, 27 October 2015, 10:06:24 »
Curious as well. Whenever I unplug and replug, the LEDs turn off. I'm using a Mac (had to download some firmware before for another problem) so maybe that's it?
Offline 1swt2gs
  • DOGE
« Reply #3 on: Tue, 27 October 2015, 10:26:18 »
Damnit mine forgets it when I unplug. I wonder what the problem is.
I had to download a new firmware because I am also using it on Mac, and it would have problems waking up on sleep.
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
« Reply #4 on: Tue, 27 October 2015, 10:30:29 »
Same issue here. On my poker 2 the LED setting is not saved after unplugging or powering down. PC user here.
Offline 1swt2gs
  • DOGE
« Reply #5 on: Tue, 27 October 2015, 15:36:06 »
Double checked with the manual
https://adprice.fedorapeople.org/poker2_manual.pdf
It specifically says "backlight status and brightness will be saved after power down."
