Author Topic: should i try a raid5 on my laptop using SD cards? what else to do with minipci??  (Read 3198 times)
Offline sth
  • 2 girls 1 cuprubber
i had a super stupid  idea that might actually work. im getting a laptop with maybe 2 free minipci slots and i was thinking (just for "FUN", what a riot) that i could get a couple of mPCI dual SD card readers and 4 SD cards, then make a raid5 array out of it to increase the storage.
how stupid is this? it's probably a waste of money but i honestly don't know what else to do with the extra minipci slots. it already has wifi and BT and i dont need wwan (or BT for that matter but it's onboard already afaik).
otherwise, what else could i do to use up those slots? what's the deal with minipci memory expansions?
Netbooks and sub-miniature notebooks use minipci SSDs as hard drives, pretty sure these would be more reliable than SD cards but a raid5 would be much more fun as you say.  Obviously you wouldn't have a hardware raid controller but sounds like a nice laptop with some unused CPU cycles.
Also you realise raid5 will only give you the capacity of three cards, with the fourth being used for data redundancy?  A raid0 stripe theoretically gives you more speed and capacity with less processor overhead, but one dead card means bye-bye data.  Also how good are the dual SD adapters?  Do they support sleep or will they drain your battery?
The only other use I know of for minipci is GPS if that's of any interest?
Offline sth
good points. raid5 is probably good enough, this would most likely be mounted as /home/sth/music and read from much more often than write. i should definitely look into sleeping it though.
probably not but i was also thinking about a radio card just for fun.
Offline sth
From my little bit of research it looks like the power draw might be more directly related to the SD cards themselves -- as long as i got 'nice' cards (sandisk or something) it should hopefully reduce draw once its done with r/w.
getting cards that i KNOW work well is another matter entirely :(
