Author Topic: What kind of hole does Gaote red/brown switch needs?  (Read 2711 times)
Offline pink_panther
    • Pink panther
« on: Wed, 28 October 2015, 05:51:50 »
I'm trying to build cheap ergonomic board, and right now designing the plate. So I've found these switches http://techkeys.us/collections/accessories/products/keyboard-switches  for 0.3$ per unit, and reviews seem to be alright. However it says "Please note: the Red and Brown switches are Chinese made MX-Compatible Switches, and while fitting and functioning the same have a different style housing.". So, what kind of holes do I need to cut in my plate to fit these switches?
P.S.
I'm new to this, so I might be lacking some of the knowledge that is trivial for an average geekhacker.
« Last Edit: Wed, 28 October 2015, 05:57:38 by pink_panther »
I evaluate regular expressions with regular expressions.
Re: What kind of hole does Gaote red/brown switch needs?
« Reply #1 on: Wed, 28 October 2015, 05:58:06 »
The difference in the housing is the way the top latches to the bottom. In the pic you've got you can see how the switch on the right has two legs holding top to bottom and the one on the left has a single leg that is horizontal.
The fit for the plate opening is the same but I'm not sure if you want a modified plate that allows for switch top removal if it would work with the switches on the left.
You can also get gaterons from www.mechanicalkeyboards.com for the same price.
« Last Edit: Wed, 28 October 2015, 06:02:04 by SpAmRaY »
    • Pink panther
« Reply #2 on: Wed, 28 October 2015, 06:23:16 »
Thanks! Hovewer I only need 60 switches, and for the same price I get either 60 or 100, does this forum organize some sort of co-op purchases?
« Reply #3 on: Wed, 28 October 2015, 06:33:01 »
What switches are you looking for specifically? i.e. red, brown, blue etc
    • Pink panther
« Reply #4 on: Wed, 28 October 2015, 06:51:01 »
I don't really know, never owned a mechanical keyboard. I think any of those would do.
« Reply #5 on: Wed, 28 October 2015, 06:53:18 »
PM me your address and I'll send you a few different switches, it isn't the same as having a full board but at least you'll have some idea before you commit.
