Author Topic: Metal keycaps?  (Read 2661 times)
Offline OrcsInSpace
Metal keycaps?
« on: Wed, 28 October 2015, 09:33:11 »
Looking around, all I can find is zink coated caps on amazon, and a set of anodized aluminum keys for the shift, alt, ctlr keys.
Are there any anodized aluminum/titanium keys available anywhere?
Re: Metal keycaps?
« Reply #1 on: Wed, 28 October 2015, 09:34:51 »
eBay might have some zinc caps but I don't know of any readily available aluminum and titanium caps.
Offline zzyjayfree
Re: Metal keycaps?
« Reply #2 on: Wed, 28 October 2015, 11:05:04 »
try geekkeys, they have plenty under HolyOops
OTD 360 Corsa w/ Nixdorf, OTD 356.2 DGE, Matrix 1.2, Matrix 2.0, Matrix Abel, Skog, Dolphin, EM7, Lynn Pad, Plank, LZ-RE, EqualZ, Orion v2, Octagon v2, Viper v2, Tank, Mira, Mira SE, Moon, Camp 225, Let's Split, HHKB, RealForce, Infinity Ergo, Cherry 3700, DolchPac, Nixdorf, Model M, Filcos.
Offline happyturtlee
Re: Metal keycaps?
« Reply #3 on: Wed, 28 October 2015, 15:32:38 »
Seconded. I have some pretty sweet Avengers caps from HolyOops but it's not a full set if that's what you're looking for. I see some RGB mods on the site also.
Offline MajorMajor
  • Mechanical Keyboard Enthusiast
    • Coding Supply
Re: Metal keycaps?
« Reply #4 on: Wed, 28 October 2015, 16:47:50 »
Pretty sure I've seen some cheap ones on Amazon.
TKL / Clears / Dvorak / Flipped Space for Life / Best Programming Keyboards
