Author Topic: Ducky Zero DK2108SZ some keys stopped working randomly  (Read 2183 times)
Offline pnut03
« on: Thu, 29 October 2015, 01:35:27 »
With the Zero DK2108SZ some keys stopped working completely for some random reason. The leds are still working. Here are the list of keys not working:
Numpad:
7,8,9 and +
Arrows:
Up arrow
Thats pretty much it that has stopped working, I play lots of games and some of these keys are not needed but i also sometimes try to use blender to model or Unity to make a game and they could come in handy. Any help?
Re: Ducky Zero DK2108SZ some keys stopped working randomly
« Reply #1 on: Thu, 29 October 2015, 03:49:23 »
That sounds like a break in the matrix but it's not the same layout as my Ducky Zero so I can't suggest a "magic" fix.  If you have a soldering iron and some fairly thin wire (any kind will work but I find stiff is easier for this work) it should be easy enough to fix :)
As to what needs soldering where we'll need a pic of that area of the PCB taken from an angle where you can see the lines (traces) which connect things - bigger is better but in focus and a good angle is most important.
