Author Topic: Hi everybody!  (Read 1517 times)
Offline hyperhopper
Hi everybody!
« on: Thu, 29 October 2015, 15:14:19 »
+/I've been a lurker on /r/mechanicalkeyboards for a while and decided to make an account here since there seems to be a lot more discussion here. I'm a developer and a gamer, so I spend at least 12+ hours a day at a keyboard, making them very important for me.
I bought a blackwidow stealth with browns when they were new, but it recently died and I'm in the market for a replacement keyboard that I can use for both coding and gaming. Right now I'm looking at the Code keyboard, the poker 3, and the CM Novatouch.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
Re: Hi everybody!
« Reply #1 on: Thu, 29 October 2015, 15:15:51 »
Welcome to GH and the wonderful world of keyboards! It could take a while until you find what you really like, and until then it is fun to find this out :)
Offline ripwallet
Re: Hi everybody!
« Reply #2 on: Thu, 29 October 2015, 15:22:44 »
Love my novatouch they can usually be bought second hand for pretty cheap. Definitely take the time to see what size is best for you.
Offline hyperhopper
Re: Hi everybody!
« Reply #3 on: Thu, 29 October 2015, 16:09:21 »
Since I have keycaps already I was thinking of getting in on this massdrop, but that ends in 3 days.
Re: Hi everybody!
« Reply #4 on: Sun, 01 November 2015, 01:34:52 »
Welcome to Geekhack!
Any of the three keyboards you have listed will be great!
The CODE can ping a bit, especially with stiffer switches, although mine with MX clears has a very quiet ping when it pings at all.
Pok3r is fantastic if you are looking for a 60% keyboard (also consider HHKB).
NOvatouch is a good compromise between Topre and MX, although it is only available in 45g variant at this stage.
