Author Topic: SA spacebar on mx Blue  (Read 4036 times)
Offline Bevo
« on: Thu, 29 October 2015, 17:39:53 »
SO i finally have a complete Hack'd geeks after not receiving the 6.2u spacebar in the original set. I ended up having to order one from Signigature Plastics for ~$21AUD which kinda sucks but i'm happy the set is finally complete.
I have it on my KBT keyboard with mx blues but the spacebar does not seem to return all the way up to the top after depression. I think due to how heavy the new spacebar is compared to the stock one.
Any ideas on how to fix this? I tried taking spring under my Realforce spacebar and putting it under the blue switch but i think its too light and doesn't really help much.
Offline FrostyToast
  • Litshoard
Re: SA spacebar on mx Blue
« Reply #1 on: Thu, 29 October 2015, 17:44:04 »
Replace the spring on your switch with something heavier.
You will need a soldering iron though.
Quote from: elton5354
Offline Bevo
« Reply #2 on: Thu, 29 October 2015, 17:55:18 »
Yeah i have a spring from a green swicth but no soldering iron :(
Offline lucaslink
« Reply #3 on: Thu, 29 October 2015, 21:57:13 »
hakko 936 clone on the super cheap. http://www.hobbyking.com/hobbyking/store/__24789__Soldering_Station_with_Adjustable_Heat_Range_with_AUS_Plug.html
decent beginner station, and good pricing for our Australian brethren.
*be sure to check ebay as you might be able to find it a little cheaper shipped within Australia.
« Last Edit: Thu, 29 October 2015, 21:59:36 by lucaslink »
Offline Bevo
« Reply #4 on: Thu, 29 October 2015, 22:10:15 »
Awesome. Thanks for that bro! You Canadians always looking after us.
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
« Reply #5 on: Thu, 29 October 2015, 22:16:27 »
This is the exact frustration I had after installing my Signature Plastics SA Symbiosis keyset on mx Clears. The spacebar would return IF you bottomed out the switch, but if you were gentle with your space keystrokes, the switch would not fully return. I ended up selling the set as I don't have enough experience soldering to feel comfortable desoldering the LED. OP if you do end up going through with the desoldering, would you mind updating us on how it goes?
Offline lucaslink
« Reply #6 on: Thu, 29 October 2015, 22:22:24 »
if you need any help with the desoldering/soldering just let me know. you'll definitely need a solder sucker as well.
« Reply #7 on: Thu, 29 October 2015, 22:48:32 »
I have the same problem on my Ducky with MX blues and MX green on the space bar.
Kinda makes the set unusable, although the Cherry stabilisers might be a contributing factor as well.
Offline Oobly
« Reply #8 on: Fri, 30 October 2015, 01:24:13 »
Sounds like you all have some sticking stabilisers. The switch on it's own can definitely return the spacebar to the top, all MX switches can do that with an SA spacebar, so I don't think modding / replacing switches is the way to go, but rather checking / adjusting / lubing your stabilisers.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Bevo
« Reply #9 on: Fri, 30 October 2015, 10:25:44 »
All i have is some wd40. I will try dab a bit of that on the stabs and see if that makes a difference. Will report back in a couple of days.
  • Dingo babies
    • IG
« Reply #10 on: Fri, 30 October 2015, 10:31:00 »
Oobly I thought the same so I lubed the stabilizers around the spacebar but still had the same problem with the SA spacebar. Bevo, you should get some white lithium grease instead of WD-40. You can find this grease at any autoparts store for >$5. Give the grease a try, if it works Hooray! If not, you may have to proceed with swapping springs or settling for a non-SA spacebar.
Offline Bevo
« Reply #11 on: Fri, 30 October 2015, 10:43:51 »
Hmm definitely worth a try. I'll head down to the shops tomorrow to see if that is available. I definitely want to try exhaust all my other options before desoldering the switch and changing the spring.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #12 on: Fri, 30 October 2015, 12:17:19 »
Yeah WD40 will erode plastic, definitely go with silicon based grease or white lithium grease.  :thumb:
Offline Oobly
« Reply #13 on: Fri, 30 October 2015, 14:25:30 »
I have heard of some spacebars having slightly different stem spacing, but all my Cherry stab boards take all my SA sets fine. The SA spacebar is symmetrical so you can also try flipping it to see if that helps. If flipping and lubing don't help, see if you can measure the stem spacing really accurately somehow. If it's faulty SP may be willing to replace it for you.
