Author Topic: Slippery Unicomp keys?  (Read 3213 times)
Offline GenEric35
« on: Sun, 08 November 2009, 19:12:38 »
Hi, I recently bought a Unicomp keyboard and I find the top of the keys are slippery.
I always clean them with alcohol and even right after cleaning they still are slippery.
Is it because it's new, does it need to wear out? my model M doesn't seem to have this problem
« Last Edit: Sun, 08 November 2009, 19:18:43 by GenEric35 »
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline GenEric35
« Reply #1 on: Sun, 08 November 2009, 20:30:12 »
Quote from: ripster;131097
Welcome to Geekhack!
Not sure what's going on there.  Haven't noticed that one and I'm convinced they didn't change the plastic.
You could always take some fine sandpaper to scratch it up a bit.
it was like that since the day i got it, like some clearcoat or something, there was no grip at all
I used a steelbrush since i had it nearby, turned out ok, for now
thanks for the tip
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline PRISONER 24601
« Reply #2 on: Sun, 08 November 2009, 22:13:44 »
I keep hearing strange inconsistencies about unicomp boards/service
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline ch_123
« Reply #3 on: Mon, 09 November 2009, 03:40:16 »
Quote from: PRISONER 24601;131122
The boards are great, the finish is not.
« Reply #4 on: Mon, 09 November 2009, 03:44:06 »
fair enough
but if i buy a unicomp and it's got slippery keys, i'm blaming ripster and ch_123
Offline ch_123
« Reply #5 on: Mon, 09 November 2009, 03:53:14 »
It's really luck of the draw with their stuff, especially as of late. Tbh, unless you want USB, I'd get one of these.
« Reply #6 on: Mon, 09 November 2009, 15:40:10 »
I couldn't do a term paper last week because my ALT key was feeling under the weather :(
Offline ch_123
« Reply #7 on: Mon, 09 November 2009, 15:42:35 »
Quote from: ripster;131220
I don't think the  Unicomp has changed in quality.
"No injection moulding leftovers here!"
Offline Hak Foo
  • Make America Clicky Again!
« Reply #8 on: Mon, 09 November 2009, 23:41:06 »
When I dyed my keys, they developed a much "dryer" feel, both on a near-new Unicomp and a 1992 1391401.
Overton130, Box Pale Blues.
