Author Topic: Varmilo aluminum case for a Phantom?  (Read 1958 times)
Offline strict
  • TKL Zealot
« on: Sun, 01 November 2015, 08:35:11 »
Anyone tried putting a Phantom in one of these? I'm debating picking one up to have a nice aluminum case to go with my newly built ANSI 150 Phantom. I know I would need to get a daughter board for the USB port but I'm sure that's something I could figure out with enough time poking around DigiKey or Mouser. Just not sure about the mounting holes for the plate and whether or not it would have enough clearance for the Teensy.
Aluminum Case For Varmilo 87 Key - MassDrop
Offline Flossed
  • Hai
Re: Varmilo aluminum case for a Phantom?
« Reply #1 on: Sun, 01 November 2015, 13:30:14 »
Don't think it'll fit. Those stand offs are going to be a problem. You might have better luck getting a Vortex aluminum case.
