Author Topic: Cooled wrist rest  (Read 3017 times)
Offline alexjd99
  • oozing through the cells of one's own construction
Cooled wrist rest
« on: Sun, 01 November 2015, 16:09:54 »
So a while ago I made a water cooled wrist rest, after seeing the heated wrist rest (by Varmillo, I think)
Printed in two separate parts, sealed with practically countless coats of resin (to make it watertight), and filled with water.
Has anyone else done anything similar?
Offline neverused
Re: Cooled wrist rest
« Reply #1 on: Sun, 01 November 2015, 17:26:51 »
Is there active circulation or does it act like a passive heat sink?
Offline Jokrik
« Reply #2 on: Sun, 01 November 2015, 17:37:57 »
I personally use wrist rest made of marble
it's cooling :)
Offline alexjd99
« Reply #3 on: Sun, 01 November 2015, 17:39:22 »
Passive heat sink, just filled with water and cooled. It would be cool to see someone hook up a wrist rest to a water cooling loop
Offline tofgerl
« Reply #4 on: Mon, 02 November 2015, 03:32:44 »
it's cooling :)
Are you Patrick Bateman?
Offline sth
  • 2 girls 1 cuprubber
« Reply #5 on: Mon, 02 November 2015, 03:38:27 »
 i want to hate on this but i just can't. well done.
nice avatar too :D
« Reply #6 on: Mon, 02 November 2015, 08:33:40 »
Ha this is so much fun. Do you have any pictures from your build process? I've never seen this before.
Offline alexjd99
« Reply #7 on: Mon, 02 November 2015, 10:20:56 »
Unfortunately I didn't. I can upload the files for this later, and include the build process in the instructions. I'll be sure to post here once I do upload.
