Author Topic: Carry case or sleeve for Topre RealForce 104UB?  (Read 2214 times)
Offline hyp36rmax
« on: Sun, 01 November 2015, 20:13:38 »
Are there any carrying cases or sleeves that fit the Topre RealForce 104UB?
Cooler Master Rapid Stealth (Brown) |  Rapid-i (Blue) | XT (Brown) | XTi (Green) | XTi (Blue) | Novatouch TKL (Topre) | Topre RealForce 104UB (Topre)
Re: Carry case or sleeve for Topre RealForce 104UB?
« Reply #1 on: Sun, 01 November 2015, 20:17:55 »
There's a couple gamer type bags for full size keyboards but they're older not sure if you could find one now or not.
Thermaltake made one and maybe Razer and there was another older one but I forgot who made it.
« Last Edit: Sun, 01 November 2015, 20:20:10 by SpAmRaY »
Offline raymogi
« Reply #2 on: Sun, 01 November 2015, 20:18:56 »
http://1upkeyboards.com/index.php?cPath=1_9
All of my sleeves came from 1up and the quality is nothing but perfect.
Please feed my addiction.
Offline hyp36rmax
« Reply #3 on: Sun, 01 November 2015, 21:16:33 »
Thanks for the suggestions!  I currently use the Chiton Grifiti which fit perfect for the slimmer boards.  Not to sure about the RealForce 104UB.
