Author Topic: RC930 RGB on MD  (Read 7119 times)
Offline trenzafeeds
  • **** off
RC930 RGB on MD
« on: Mon, 02 November 2015, 11:15:14 »
https://www.massdrop.com/buy/royal-kludge-rc930-rgb/talk
Interesting, it's the first RGB Topre clone I've ever seen. I've never personally tried the Royal Kludge switches though, and the RGB backlight looks mediocre at absolute best.
demik will never leave.
Unless he gets banned.
Offline Niomosy
Re: RC930 RGB on MD
« Reply #1 on: Mon, 02 November 2015, 18:42:44 »
Thinking about it.  I wish it was 45g switches.  Not positive on the 55g at the moment.  I'm an MX reds man and used to lightweight switches.
Offline trenzafeeds
  • **** off
Re: RC930 RGB on MD
« Reply #2 on: Mon, 02 November 2015, 18:44:29 »
If you're going for your first topre experience, I would go with real topre if you can afford it. This is more of an experimental thing.
Re: RC930 RGB on MD
« Reply #3 on: Mon, 02 November 2015, 19:06:40 »
You do realize these aren't exactly new right? They've been reviewed and we'll received.
Offline trenzafeeds
  • **** off
Re: RC930 RGB on MD
« Reply #4 on: Mon, 02 November 2015, 19:07:46 »
Even with RGB?
Re: RC930 RGB on MD
« Reply #5 on: Mon, 02 November 2015, 19:08:30 »
Even with RGB?
Pretty sure people were trying the RGB ones first.
Offline trenzafeeds
  • **** off
Re: RC930 RGB on MD
« Reply #6 on: Mon, 02 November 2015, 19:10:00 »
I had no idea! I was worried that adding RGB lighting might have affected how they designed the switch like it did on the earlier K70's, but I didn't realize people had already demoed RGB models.
Re: RC930 RGB on MD
« Reply #7 on: Mon, 02 November 2015, 19:13:15 »
The RGB lighting isn't new, I noticed the drop said V2 so it's possible something is different but as far as the backlighting goes expect to see even Type Heavens coming soon with that feature.
Offline Niomosy
Re: RC930 RGB on MD
« Reply #8 on: Mon, 02 November 2015, 19:13:23 »
I'm less interested in a real Topre and more interested in an economically priced keyboard with Topre switches that I can put Cherry compatible keycaps on, given I'm likely delving into at least 2-3 SA sets in the upcoming months.
I might eventually delve into Topre more fully and buy a Realforce board but that price is a heavy driving force in keeping me away - particularly when I'm interested in the Axios and would focus money there first.  The Kludge would be a cheap enough purchase that I wouldn't overly worry about it.
Offline trenzafeeds
  • **** off
Re: RC930 RGB on MD
« Reply #9 on: Mon, 02 November 2015, 19:15:06 »
This sounds like it would actually be a pretty great choice then. If you're ok with 45g the Novatouch isn't that ridiculous either.
Re: RC930 RGB on MD
« Reply #10 on: Mon, 02 November 2015, 19:15:09 »
I wasn't overly impressed with SA on a royal kludge, but the royal kludge itself is a decent board.
Re: RC930 RGB on MD
« Reply #11 on: Mon, 02 November 2015, 19:15:59 »
I would take the royal kludge over novatouch any day.
Offline Niomosy
Re: RC930 RGB on MD
« Reply #12 on: Mon, 02 November 2015, 19:18:15 »
I've heard at least a couple people mention that.  I'm curious, but wondering about the 55g switches.  I'm normally working on MX reds at home and am used to light switches.  Blacks fatigued me after a while so I'm wondering if the 55g Topres will also cause the fatigue.
Worst case, I keep storing up Amazon credit and basically get a NovaTouch for free eventually.
Re: RC930 RGB on MD
« Reply #13 on: Mon, 02 November 2015, 19:25:40 »
There's so much personal preference and the feeling changes depending on what caps you use also.
Offline saturnotaku
Re: RC930 RGB on MD
« Reply #14 on: Mon, 02 November 2015, 19:47:54 »
At first glance, there appear to be two noticeable differences with the Gen 2 model. First is a translucent housing around the plunger, presumably to let the light shine through better. Second is an additional lighting zone that goes around the outside of the alphanumeric cluster from Esc, across the bottom row, and ending at backspace. Evolutionary changes, to be sure, but the price is still very good.
Offline mobbo
  • u fk
Re: RC930 RGB on MD
« Reply #15 on: Mon, 02 November 2015, 19:51:30 »
What's different about SA caps on a Royal Kludge? I'm also getting a few SA sets and was wondering about this board vs. the Novatouch.
Someone posted a video on reddit of their modded v1 and it sounds really nice.
Quote from: Binge
Re: RC930 RGB on MD
« Reply #16 on: Mon, 02 November 2015, 19:52:35 »
Again it's probably more personal preference, it just wasn't my thing.
Offline mobbo
  • u fk
Re: RC930 RGB on MD
« Reply #17 on: Mon, 02 November 2015, 20:02:43 »
But was it how they looked? How they felt?
Quote from: Binge
Re: RC930 RGB on MD
« Reply #18 on: Mon, 02 November 2015, 20:10:06 »
I just didn't care for the overall experience with SA caps.
 I like the royal kludge with the thick Leopold pbt caps.
Offline btctopre
Re: RC930 RGB on MD
« Reply #19 on: Mon, 02 November 2015, 23:07:59 »
just be sure to remove the pre-installed o-rings if you buy a kludge, it's a decent value purchase after they're off.
Offline whmeltonjr
Re: RC930 RGB on MD
« Reply #20 on: Mon, 02 November 2015, 23:15:53 »
If I've never tried a Topre board at all, is this a decent option to try first? I know it's not real Topre switches, but it also isn't $200 for a board I may not like.
Re: RC930 RGB on MD
« Reply #21 on: Tue, 03 November 2015, 06:25:56 »
Tell me more? I didn't see any o-rings on mine.
Offline mobbo
  • u fk
Re: RC930 RGB on MD
« Reply #22 on: Tue, 03 November 2015, 09:25:46 »
How about SA caps on the Novatouch? Have you had an opportunity to try that combination out?
Quote from: Binge
Offline Touch_It
Re: RC930 RGB on MD
« Reply #23 on: Tue, 03 November 2015, 09:54:33 »
Will probably have to pass, but lets say I got one, and put a quality set of thick caps on it.  Would I be disappointed if I tried this side by side with a 55G switch realforce?  Also how would it compare to a typeheaven (my only experience with topre).
Re: RC930 RGB on MD
« Reply #24 on: Tue, 03 November 2015, 09:56:43 »
I have not.
It's no realforce but its cheaper and uses MX caps, unless you have a 55g realforce then you don't have to worry about making a comparison. :D
To me the type heaven is underated, I'm curious to see what the new type heaven with mx compatible stems is like.
I also like the royal kludge for its thin bezel compared to realforce boards.
« Last Edit: Tue, 03 November 2015, 10:00:13 by SpAmRaY »
Offline mobbo
  • u fk
Re: RC930 RGB on MD
« Reply #25 on: Tue, 03 November 2015, 19:54:18 »
I think I'm gonna pick one up at that price and see how thocky I can get it. Looks like the perfect board to put more keycaps on.
Quote from: Binge
Offline jaffers
Re: RC930 RGB on MD
« Reply #26 on: Wed, 04 November 2015, 04:13:03 »
I do remember seeing this particular keyboard (V1) on massdrop a while back, its not new by any means. But it does look interesting. A much cheaper alternative to topre's and I'm definitely interested in them as I haven't tried topre's myself.
It kinda sounds like its rubbing on something while the key is being depressed and I'm kinda attracted to that. Looks Sounds like it feels good
« Last Edit: Wed, 04 November 2015, 04:16:15 by jfing14 »
