Author Topic: Numpad options? (Cherry switch if possible)  (Read 2326 times)
Offline 1swt2gs
  • DOGE
« on: Sat, 07 November 2015, 19:42:23 »
I have been looking for a Numpad with Cherry switches without no avail.
I would build my own preferably using Zeal switches or a different switch, but seeing as to how I don't know how to solder I don't want to mess anything up.
That said, anyone know options regarding Cherry Mx switched numpads?
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline jerue
  • (Whenever that happens :P)
Re: Numpad options? (Cherry switch if possible)
« Reply #1 on: Sat, 07 November 2015, 19:50:12 »
You have some options
Leopold/Filco
b.pad
356pad (if you can find one)
ADESSO AKP-220B
Realforce 23ub (just get this and convert to cup rubber goodness)
many more I am missing
Offline 1swt2gs
  • DOGE
« Reply #2 on: Sat, 07 November 2015, 19:53:11 »
Leopold/Filco
b.pad
ADESSO AKP-220B
Thanks Trev!
I'll go ahead and look those up.
Offline Dernubenfrieken
« Reply #3 on: Sat, 07 November 2015, 20:04:32 »
Leopold/Filco
b.pad
ADESSO AKP-220B
Thanks Trev!
Goldtouch I believe is the most common numpad also.
Offline Bucake
« Reply #4 on: Sat, 07 November 2015, 20:40:08 »
if you decide to go with the Leopold FC210TP, then i would make sure if it sends 'proper' keycodes.
because some versions send out the proper numpad-codes, while others send out 'normal number' codes.
« Reply #5 on: Sat, 07 November 2015, 20:43:06 »
g80-3700
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Sat, 07 November 2015, 21:06:25 »
Leopold/Filco
b.pad
ADESSO AKP-220B
Thanks Trev!
I stumbled into a Goldtouch numpad at the recycling centre a while ago, it was a nice piece of kit :) .
Offline Macsmasher
« Reply #7 on: Sat, 07 November 2015, 21:18:54 »
I got this Adesso a few years ago and sent it back:
http://www.amazon.com/ADESSO-AKP-220B-Adesso-Mechanical-Numeric/dp/B0038KN3YY/ref=sr_1_1?ie=UTF8&qid=1446952253&sr=8-1&keywords=ADESSO+numpad
It has a funky key layout. In fact, my review is still the top review hahaha. November 5th, 2012. Point is, not all numpads have the same layout so be sure to check out the pictures.
I ended up buying a RF 23U and have no regrets. And it does send the correct key codes.
« Reply #8 on: Sat, 07 November 2015, 21:19:40 »
g80 3700 is the best imo, OG cherry
Offline ika
« Reply #9 on: Sat, 07 November 2015, 21:25:04 »
You can also have Hojin at winkeyless build you a custom b.pad. won't be cheap for everything soldered though.
