Author Topic: Replacing Blackwidow keycaps on a Novatouch  (Read 3461 times)
Offline hyperhopper
« on: Mon, 09 November 2015, 20:25:08 »
My blackwidow recently died so I decided to buy the barebones novatouch on massdrop and use the blackwidow keycaps on it. However, I realized after the fact that blackwidow keycaps have non standard sizing on the bottom row.
What size keycaps would fit the bottom row of the novatouch, and do you have any inexpensive reccomendations on where to buy them?
Offline asdfjkl36
  • blue shirt guy
Re: Replacing Blackwidow keycaps on a Novatouch
« Reply #1 on: Mon, 09 November 2015, 20:33:03 »
uh, what is it...
1.25 - 1.25 - 1.25 - 6.25 - 1.25 - 1.25 - 1.25 - 1.25 (Edit: 6.25 not 6.5)
Tai Hao keycaps are nice to get started with. Cheapish and they're doubleshot (thin ABS though) so the letters wont wear out.
https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=40
I Probably have some stock QuickFire Rapid or possibly my stock novatouch keycaps if you'd like to have those for the cost of shipping.
Allows you the time to save up money for some decent keycaps :)
« Last Edit: Mon, 09 November 2015, 20:41:25 by asdfjkl36 »
Offline FrostyToast
  • Litshoard
« Reply #2 on: Mon, 09 November 2015, 20:38:35 »
1.25 - 1.25 - 1.25 - 6.5 - 1.25 - 1.25 - 1.25 - 1.25
The bottom row in the main typing section should add up to 15 units.
With what you just posted, that would give you 15.25 which obviously wouldn't fit.
Should be 1.5 - 1 - 1.5 - 6 1.5 - 1 - 1 - 1.5. It's essentially Tsangan + 1.
6x keycaps aren't very standard at all but you can get them individually here.
EDIT: Oops. I am dumb. Novatouches use a standard bottom row with a 6.25 spacebar. That layout I listed was for the Blackwidow.
6.25 spacebars are very common and the link I posted will still have what you need.
« Last Edit: Mon, 09 November 2015, 20:42:14 by FrostyToast »
Quote from: elton5354
Offline asdfjkl36
  • blue shirt guy
« Reply #3 on: Mon, 09 November 2015, 20:42:58 »
My fault. Didnt have my glasses on and didnt noticed i missed the "2" in 6.25.
Just a standard layout:
Offline FrostyToast
  • Litshoard
« Reply #4 on: Mon, 09 November 2015, 20:44:28 »
Yeah you're still right about the Tao Hao caps. They're highly affordable and good for the price. Though if you were to get a novatouch I would expect you to purchase something higher in quality.
Offline asdfjkl36
  • blue shirt guy
« Reply #5 on: Mon, 09 November 2015, 20:48:03 »
Exactly. I have my Novatouch with my GMK TA and it feels great. Tai Haos arent gonna cut it.
The stock keycaps are decent, so that could at least hold him over for a bit.
If not, maybe some Gateron PBTs will do the job, though they're blank :P
Offline hyperhopper
« Reply #6 on: Mon, 09 November 2015, 21:05:38 »
Thank you so much for the offer! I'll send you a PM!
« Reply #7 on: Tue, 10 November 2015, 03:22:48 »
Offline MeltingTeeth
« Reply #8 on: Tue, 10 November 2015, 11:08:58 »
Also Vortex PBTs on MechanicalKeyboards.com.
Offline nocturalowl
« Reply #9 on: Fri, 13 November 2015, 11:13:26 »
I second on vortex pbt. It feel rather nice on my silenced novatouch.
