Author Topic: TKL with Hybrid Switches  (Read 2887 times)
Offline Incredigasmic
  • Orange is Love. Orange is Life.
« on: Thu, 12 November 2015, 11:09:12 »
Putting together my first B.87 and I'm trying to determine which switches I want on it. I know I don't like the typical "clicky" switches and the Browns feel most natural to me, but Clears also feel great. Any suggestions on how I should set them up? Clear alphas and Brown mods? I'll be using it for quite a bit of gaming too. Thanks for any and all input.
"If I married my 6th grade gf I'd be white trash...7th grade I'd be alright" ~ Binge
"Incredi is the foremost master of all things orange" ~ BroCaps
Offline saturnotaku
Re: TKL with Hybrid Switches
« Reply #1 on: Thu, 12 November 2015, 11:29:52 »
I'd stick with lighter switches if you're going to be gaming a lot. I personally don't care for how heavier ones feel when playing.
« Reply #2 on: Thu, 12 November 2015, 11:39:14 »
So brown Alphas and red mods?
« Reply #3 on: Thu, 12 November 2015, 11:41:22 »
« Reply #4 on: Thu, 12 November 2015, 13:33:13 »
Can't justify $1 per switch QQ
Offline mobbo
  • u fk
« Reply #5 on: Thu, 12 November 2015, 13:39:46 »
I'm probably not one to give any advice as I'm still learning but I own browns, clears, blues, and reds.
Do you find the clicky switches just as bad on modifiers? I prefer to type on clears the most - browns second, but sometimes I think having a blue spacebar might be pretty cool.
Personally I'd go browns for alphas and something a little firmer for the modifiers, but it seems like you are of the opposite opinion
Quote from: Binge
« Reply #6 on: Thu, 12 November 2015, 13:55:49 »
I'm just thinking of pressing the mods with my pinkies and how difficult it would be during gaming.
« Reply #7 on: Thu, 12 November 2015, 14:10:21 »
« Reply #8 on: Thu, 12 November 2015, 14:15:02 »
:P
xD Zealios are ok, but the switch isn't worth the cost to me. It just don't feel as nice as Browns or Clears :/
« Reply #9 on: Thu, 12 November 2015, 14:20:54 »
:P
Ah, well I have tried (and still use) all three, and I would have a strong preference toward Zealios for tactile switches. If not for the high cost, like you said.
I have tried to use mixed browns and clears like you are proposing, but I found that I highly prefer uniform to mixed. I like both stock clears and browns about the same. I slightly prefer 65-68g lubed clears, if going with a customized switch.
For linears, I HIGHLY prefer 65g lubed blacks over either stock blacks or reds. But I use boards with both stock blacks and reds all the time. :)
Clicky MX switches I cannot abide. Clicky Alps are okay, but I prefer dampened tactile Alps, such as Matias Quiet Clicks.
