Author Topic: [IC] Aquamarine Keycap set  (Read 3809 times)
Offline trenzafeeds
  • **** off
« on: Fri, 13 November 2015, 04:21:46 »
Just messing around with a new water-based colorway that popped into my head, thought I'd see what people think.
Possible base
Another base idea
Variation on second idea (slightly different alpha colors)
Whichever alpha set I didn't use would probably be turned into a mod set, and then I would do another mod set (if there's enough interest) in reverse colors of the alphas which would obviously be a lot brighter.
Here's an example of reverse mods with the first set of alpha colors. Personally I think it looks nice, if a bit NSFW.
I also would like to do icon mods with this if that's something others are interested in.
demik will never leave.
Unless he gets banned.
Offline njbair
    • nickbair.net
Re: [IC] Aquamarine Keycap set
« Reply #1 on: Sat, 14 November 2015, 21:07:44 »
Reminds me of Bubble Man. I like it.
My boards:
Offline arcvile
« Reply #2 on: Mon, 16 November 2015, 10:25:05 »
I'd love to see the blue in a two tone. You have my interest just no quite my wallet yet.
Offline zslane
« Reply #3 on: Mon, 16 November 2015, 15:43:21 »
You might find SA Dasher of interest. It won't go into wide-band IC circulation until after the holidays though.
