Author Topic: Poker lube question  (Read 1618 times)
Offline di3gopa
Poker lube question
« on: Fri, 13 November 2015, 22:16:01 »
Hi guys, newb question here:
I saw on another topic that if you feel your keys on the poker with stabilizers feel hard to press, you should lube the stabilizer. I removed the keycaps and the case of it but i can't figure out how to take out the stabilizer. Any place you guys know i can look for this? I have a Poker 3.
Happy owner of a POK3R
Offline Flossed
  • Hai
Re: Poker lube question
« Reply #1 on: Fri, 13 November 2015, 22:32:32 »
Just lube where the arrows point. You don't have to remove the stabilizers, that requires desoldering the switch.
Offline di3gopa
« Reply #2 on: Fri, 13 November 2015, 22:54:40 »
Awesome! thanks for the help!
