Author Topic: WTH is going on with my monitor!  (Read 6420 times)
Offline 1swt2gs
  • DOGE
« on: Sat, 14 November 2015, 00:29:51 »
Hopefully I posted in the right section. Figured someone here would know what's going on.
https://vid.me/mKTd
I have a Viewsonic vx2433wm 24" monitor connected to my Macbook Pro Retina 13" via HDMI.
Every time it wakes up, I get either a static flickering screen or a screen with a pink hue. I can fix the problem in 1 of 3 ways
* Putting the mac to sleep and waking it up again will fix the problem (usually have to do 2-3 times).
* Turn off/on monitor (have to do once, sometimes twice)
* Unplugging or replugging in HDMI cord
It's really beginning to bug me that I have to mess with the monitor every time the computer wakes up from sleep or powers up but I can't justify spending money on another monitor since the monitor is fully functional otherwise.
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline Coreda
Re: WTH is going on with my monitor!
« Reply #1 on: Sat, 14 November 2015, 00:38:14 »
Ah, Instagram mode.
I have no idea. Some monitors have issues when exiting power saving modes (including my own), which is why I normally turn off the monitor when shutting down.
Have you googled for issues with that monitor? If it's common usually there will be other posts about it.
« Last Edit: Sat, 14 November 2015, 00:40:01 by Coreda »
Offline 1swt2gs
  • DOGE
« Reply #2 on: Sat, 14 November 2015, 00:44:17 »
Ah, Instagram mode.
Yes, Google was the first place I looked. Nothing there.
Which monitor do you have and what problems does it have when exiting power mode?
Shutting down the monitor when I turn off my computer or sleep it, or go to bed for the night wouldn't help in my case because it has problems from the wake up.
Offline Coreda
« Reply #3 on: Sat, 14 November 2015, 00:49:17 »
It's an older 1440p Dell which can have some noisy color issues on one half. Haven't done too much testing but have read standby exacerbates the issue which is why I usually turn it off.
A quick googling for pink screen monitor issues returns some results that suggest it may be an issue with either the video cable or number of lamp hours. Have you tried a different video cable?
Offline 1swt2gs
  • DOGE
« Reply #4 on: Sat, 14 November 2015, 00:53:22 »
Yes! Have tried 2 different HDMI cables and problem still persists.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #5 on: Sat, 14 November 2015, 01:17:39 »
Can you try a different video source?  Different PC/laptop/video card?
Offline 1swt2gs
  • DOGE
« Reply #6 on: Sat, 14 November 2015, 01:24:29 »
That's actually a good idea. Can't believe I didn't think of that. Other laptop uses VGA though and i don't have a VGA cable.
Edit: Found out other laptop uses HDMI, plugged it in, played with it, put to sleep a few time and woke up it (no problems).
« Last Edit: Sat, 14 November 2015, 01:34:45 by 1swt2gs »
Offline Melvang
« Reply #7 on: Sat, 14 November 2015, 01:53:32 »
Sounds like the video card is dying.  I had a 280 GTX from EVGA that did that after a year and a half on the stock cooler.  My previous 7800 GTX still runs (if I could find all the parts to the cooler).  Since then, I won't run a video card on the stock cooler.  For every 10°C you can drop the operating temp on any electronics, you can expect approximately a 50% increase in life span.
Offline 1swt2gs
  • DOGE
« Reply #8 on: Sat, 14 November 2015, 01:55:18 »
Are we talking video card on the Mac?
Offline Melvang
« Reply #9 on: Sat, 14 November 2015, 01:57:20 »
Yes.  Though I don't know **** about Mac hardware, so I couldn't tell you if it has a dedicated video processor (I would assume so since it is the Pro and not the Air), so I could be off base here.  But that is what the symptoms point to in my head.
Offline 1swt2gs
  • DOGE
« Reply #10 on: Sat, 14 November 2015, 01:59:21 »
I hope its not the video card, as the laptop is pretty new (<1 year old).
Offline Coreda
« Reply #11 on: Sat, 14 November 2015, 17:33:29 »
Should be covered under warranty then, surely.
(also blue avatars represent ^-^)
