Author Topic: Keyboard protective cover sources  (Read 2618 times)
Offline ckckckck
« on: Mon, 16 November 2015, 11:33:19 »
I need a protective cover for a Poseidon Z RGB....
Is there a secret factory somewhere that makes them?
I'm using the one from my Ducky Shine 4, it works, but the modifier keys are smaller on this Z.
Maybe there is one that's made for a keyboard of the same dimensions?
I don't want the one-size-fits-all, shower cap, panty hose type.
Offline MeltingTeeth
Re: Keyboard protective cover sources
« Reply #1 on: Mon, 16 November 2015, 14:34:48 »
Offline neverused
« Reply #2 on: Mon, 16 November 2015, 14:57:20 »
Offline Eugene45
« Reply #5 on: Tue, 17 November 2015, 04:21:48 »
lmao, cut the French some slack, they gave you a big statue
Offline ckckckck
« Reply #6 on: Tue, 17 November 2015, 16:00:47 »
Thanks for the responses!
I need one you can type on.
This is the one I have https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=999
But it is the only one they sell.
« Reply #7 on: Tue, 17 November 2015, 16:15:57 »
I've seen some for cherry keyboards on taobao if you are familiar with using it you might find one that will fit your keyboard.
http://item.taobao.com/item.htm?id=45829448419
Offline ckckckck
« Reply #8 on: Sat, 21 November 2015, 09:05:04 »
These look really good, just need to know which ones they have that are similar to mine.
https://www.protectcovers.com/keyboard-covers.html
Offline ckckckck
« Reply #9 on: Sat, 21 November 2015, 09:28:43 »
http://www.greenonionssupply.com/special-orders/custom-cut-screen-protectors/
Makes them too, I have not heard back from them yet.  The last time I tried to do this, several places said NO...
Offline tronbeaver
« Reply #11 on: Sat, 21 November 2015, 10:19:41 »
Lol, wrong "keyboard".
Offline ckckckck
« Reply #12 on: Fri, 27 November 2015, 00:09:27 »
Been looking at similar keyboard layouts, none so far.
Most Tesoro and the K90 are similar, but the shift/winkey position would be an issue.
It would have been quicker to genetically engineer spiders to produce silisilk and then train them to make a web on top this keyboard.
I'm guessing a DIY is the only option for this one.
Any tips on making your own flexible, super thin keyboard protector?
