Author Topic: MK Switch Rater is back and better than ever.  (Read 86517 times)
Offline ShakeR
  • * Moderator
    • http://mechanicalkeyboards.com
« on: Mon, 16 November 2015, 14:08:44 »
https://mechanicalkeyboards.com/mechanical_switches.php
MK's Switch Rater is back and better than ever! Be sure to check it out and add your switch feedback - now with a space for comments.
If there are any not-too-obscure switches you want added to the list, let us know.
MechanicalKeyboards.com - What do you type on?
Re: MK Switch Rater is back and better than ever.
« Reply #1 on: Mon, 16 November 2015, 19:15:45 »
Did you want to differentiate between Model M buckling springs and Model F buckling springs?
Also Zealios are new, popular, and would probably make an excellent addition.
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #2 on: Mon, 16 November 2015, 20:27:51 »
Are they singles only? Are there any manufacturers out there putting them in their keyboards beyond customs?
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #3 on: Tue, 17 November 2015, 03:19:18 »
AFAIK it is only hobbyists using them in custom keyboards.
Offline ShakeR
  • * Moderator
« Reply #4 on: Thu, 26 November 2015, 20:14:29 »
Any unified specs for me to put in the Database?  (eg black stem: 55g actuation, linear)
Offline trenzafeeds
  • **** off
« Reply #5 on: Thu, 26 November 2015, 20:18:10 »
Where's gateron?
demik will never leave.
Unless he gets banned.
Offline 00zeRO
  • * Moderator
« Reply #6 on: Thu, 26 November 2015, 20:26:21 »
Where's gateron?
It is currently only for keyboards we carry with switch types. We have no keyboards with Gaterons to date
Offline trenzafeeds
  • **** off
« Reply #7 on: Thu, 26 November 2015, 20:30:14 »
Where's gateron?
Yes, that makes sense business-wise I guess.
Offline ShakeR
  • * Moderator
« Reply #8 on: Thu, 26 November 2015, 21:06:44 »
Where's gateron?
Actually, it's more about broken links / additional coding.  Most of our pages are written to link to corresponding products.  If those products don't exist, 404 errors result.  I can write catches for everything, but unfortunately only 24 hours in a day ;)  I'm always working to add functionality to the site, so hopefully not too far off (and even more hopefully - we get some boards in with Gateron switches ;D)
Offline trenzafeeds
  • **** off
« Reply #9 on: Thu, 26 November 2015, 21:17:53 »
Yes please!
Also, I should note that it does look really good! Looking forward to seeing the new additions to the site in the future!
« Reply #10 on: Fri, 27 November 2015, 03:01:57 »
The GB thread lists these variants:
    62g - Linear (Clear stem)
    65g - Linear (Clear stem)
    67g - Linear (Clear stem)
    62g - Tactile (Purple ergo-clear stem)
    65g - Tactile (Purple ergo-clear stem)
    67g - Tactile (Purple ergo-clear stem)
Offline trenzafeeds
  • **** off
« Reply #11 on: Fri, 27 November 2015, 10:15:53 »
"10/10/10 MX blacks are like strong black coffee"
Offline Homenubbie
« Reply #12 on: Fri, 27 November 2015, 10:19:14 »
Massdrop sells keyboards with Gaterons.
Offline 00zeRO
  • * Moderator
« Reply #13 on: Fri, 27 November 2015, 12:32:41 »
Massdrop is not a manufacturer. Are there brands with Gaterons in them (Razer, Cooler Master, Varmilo, etc?)
Offline ShakeR
  • * Moderator
« Reply #14 on: Fri, 27 November 2015, 15:12:12 »
Awesome
