Author Topic: New dyed M, new to site, and just killed my M  (Read 8461 times)
Offline Oqsy
« on: Sat, 14 November 2009, 21:56:14 »
Hello all, this is my first post here, although I've been reading threads here for a while and finally dyed my Model M's keys red and back last night.  However, at some point in the reassembly something went awry, and now my LEDs flash a single time (all three simultaneously) at bootup, and when I get into windows all LEDs shut off, and the keyboard appears dead after that, no LED response to the caps, num, or scroll lock keys, and no keys work.  I thought it might be a shorted wire in the cable where it enters the keyboard (pretty crimped and bent up, and the insulation was split at one place.  I cut and repaired all wires and rerouted the cable.  Still the same response when I bootup.  Any resources out there that can tell me what's wrong with the keyboard (any Model M troubleshooting FAQs etc)?  By the way, great forum and glad to see there are other people that geek out over clicky keys, Model Ms and the like.  Oh and I'll add some pics here later tonight of my dye results (I'm quite pleased!)
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline Rajagra
« Reply #1 on: Sat, 14 November 2009, 23:09:47 »
Welcome.
Do all the keys feel normal (click when you press)? If not, maybe some keys are stuck in the 'down' state, and that is causing the board to fail its self-test.
Is it an M2? They are known to sometimes have failed capacitors. The original M doesn't (at least not as often.)
Are you connecting straight to a PS/2 port or through a PS/2-USB adapter?
If PS/2, did you plug it in while the PC was off?
Offline Oqsy
« Reply #2 on: Sat, 14 November 2009, 23:53:31 »
it's a 42H1292 made in Scotland in 1999.  It's a PS/2 board, no USB involvement, and yes I connected it when powered off.  I checked all the keys and they all click and rebound normally.  I know very little about the electronics of a buckling spring, but is it possible dust/etc fell down into the mechanism and caused a short on the board, simulating a "stuck key"?  just wondering if it would be worth it to take off the caps and stems and blow some compressed air inside each switch.
Offline Oqsy
« Reply #3 on: Sun, 15 November 2009, 00:21:59 »
Here are a couple of pics...  the case is going to be NES case gray, continuing in the nintendo color theme of the board.  For those looking to dye this particular type of cap, HEAT is the key.  I soaked them in very strong dye at 150F (feared melting them at 170F as has been posted other places, especially the spacebar)... but nothing happened worth noting until i got to 200F or above.  once the water really started churning with bubbles, I could smell the dye very strongly and the keys would take the color in a matter of seconds.  Black took me about 10 dips being very careful and methodical so that I didn't ruin anything, but the red was a piece of cake.  I even did the space bar by itself at the end to make sure it wasn't deforming in the heat, but it stayed solid all the way to boil, and only took about 2 minutes of up and down heat from 190-212 (on and off the burner) with rolling boil lasting no more than 15 seconds each time.  These caps may be know to be particularly tough when boiling, but I wanted to share for anyone else out there that is afraid of melting their caps like I was.
Offline Rajagra
« Reply #4 on: Sun, 15 November 2009, 00:23:11 »
I think it's unlikely to be dust etc. I'm worried a short might have damaged something. Do you have other equipment to help isolate the problem, e.g. another PS/2 keyboard to make sure the computer port is OK, or another PC to try the model M on?
There have been cases where some computers haven't been able to supply enough power to the PS/2 port for 'legacy' kit of this age.
I have no personal experience of faulty model Ms. Maybe someone else has some ideas or a link.
Edit> Just saw the pic, the keys look stunning.
« Last Edit: Sun, 15 November 2009, 00:25:16 by Rajagra »
Offline Oqsy
« Reply #5 on: Sun, 15 November 2009, 00:30:41 »
yes, I'm using my logitech keyboard on this comp now, also a PS/2, and the model M was working perfectly before reassembly.  I was dead set on it being the split cable insulation, but now I'm a bit worried that all my work was in vain.
Offline ch_123
« Reply #6 on: Sun, 15 November 2009, 06:06:48 »
Did any of the dye get onto the controller board? (The PCB that the Leds are mounted onto)
Fortunately, you can get a new 42H1292 quite cheaply and just put your new caps into it.
Link
Nice mod btw.
Offline Oqsy
« Reply #7 on: Sun, 15 November 2009, 12:18:20 »
Thanks for all the responses!  I'll try everything suggested.  The keys were bone dry when I put them on the board (hairdryer ftw). The controller board was nowhere near the dying process or wet keys so it should be fine. I'll report back once I've tested and disassembled  the board.
Offline Oqsy
« Reply #8 on: Sun, 15 November 2009, 16:58:23 »
Ok, so I disassembled the board, stems and all, and the board DID boot normally into windows (numlock was illuminated at login screen).  I started replacing stems and noticed it was taking the input from the keys (right numpad) until I got to 789...  nothing.  Then I started on letters... nothing on the top row (qwerty), but some letters on lower rows worked.  I believe that the ribbon may have come loose or that the membrane has too much space between it and the switches, but I can't find a way to separate the black plastic tray from the rest of the board without cutting all the plastic rivets, and so I can't access the ribbon to disconnect and reconnect it, or to even check that there is no mechanical damage somewhere along the circuits.  Any tips for further dis-assembly, or is a new 42H1292 the only real option at this point?  I'd love the satisfaction of reviving this board, but I also know that at some point it's just not worth it anymore.  Thanks to all for their comments and advice thus far!
Offline AndrewZorn
« Reply #9 on: Sun, 15 November 2009, 17:00:14 »
i mean if you are willing to buy a new one you mind as well try anything you can to fix the old one, not let some rivets stop you from even attempting to fix one that does not work
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #10 on: Sun, 15 November 2009, 17:53:01 »
Please double check the membrane connection at the controller board. Maybe that has partly come out.
Offline ch_123
« Reply #11 on: Sun, 15 November 2009, 17:55:48 »
In a 42H1292, the controller board basically slots into the membrane (it's hard to explain, you'd have to see it for yourself) Make sure the controller is properly inserted. You may even want to take the board out and reinsert it.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #12 on: Sun, 15 November 2009, 19:45:06 »
Quote from: Oqsy;132732
I have had similar problems with my Model M after re-assembling it. If I were you, I would take it apart again and look for where the keyboard connects to the mainboard with a ribbon cable. Chances are that the ribbon cable is not plugged in properly. Gently remove it and carefully re-insert it correctly, and all the keys should work. Good luck!
Offline Oqsy
« Reply #13 on: Sun, 15 November 2009, 20:19:14 »
Is there a way to do this without separating the black tray and cutting all the rivets?  I can see the ribbon like connector at the bottom, but the angle prevents me from accessing it without bending/breaking the main board, unless there's something I'm not understanding about the physical connection of the board Nd the membrane.
Offline iMav
  • geekhack creator/founder
« Reply #14 on: Mon, 16 November 2009, 07:37:00 »
Personally, if it comes down to spliting the "frame assembly", I'd say go ahead and get a replacement 'board.
Your work will not be in vain regardless.
« Reply #15 on: Mon, 16 November 2009, 16:40:42 »
Quote from: Oqsy;132761
The mainboard is screwed into the keyboard frame and the steel plate. Look carefully for screws and undo any you find. Then you should be able to re-connect the keyboard unit.
Offline Oqsy
« Reply #16 on: Mon, 16 November 2009, 18:07:27 »
I'm pretty sure I've got it fixed, about to reboot and test.  I was able to angle the PCB out as in the pic above and slip it loose and back into place.  Also testing my new (to me anyway) NMB RT8756C+ tonight.  Should be some pics to come later.
Offline Oqsy
« Reply #17 on: Mon, 16 November 2009, 19:41:30 »
It's ALIVE!!!!!  Thanks to everyone for the help. Expect some photos of the M and the new board in the pics thread soon. Special thanks to ripster for sticking with me through this thread!
« Reply #18 on: Mon, 16 November 2009, 20:17:05 »
I'm glad to hear it's working! Good luck with it!
Offline msiegel
« Reply #19 on: Mon, 16 November 2009, 20:20:30 »
sweet :D
congratulations!
Offline Shawn Stanford
« Reply #20 on: Tue, 17 November 2009, 04:51:05 »
Speaking of the PCB: does anyone have a spare? At some point I pulled a keyboard apart for cleaning and to paint the case and the PCB is nowhere to be found...
The Brat Prince of COBOL
Offline ch_123
« Reply #21 on: Tue, 17 November 2009, 07:02:57 »
What part number is the keyboard?
« Reply #22 on: Tue, 17 November 2009, 07:12:04 »
:lol: I don't know and I have no way of finding out, since I painted the case hot-rod red - which means I painted over the label. However, I think any 'standard' Model M PCB should work.
Offline ch_123
« Reply #23 on: Tue, 17 November 2009, 07:32:30 »
Well, if you have a Unicomp or 42H1292 (i.e. controller slots into the keyboard assembly - like the one above) You'll need a different type of controller to the regular one. I actually have a spare Unicomp controller lying around which I think is still operational.
« Last Edit: Tue, 17 November 2009, 07:35:06 by ch_123 »
« Reply #24 on: Tue, 17 November 2009, 09:10:46 »
This one is the standard IBM Model M deal with the two ribbon cables.
« Reply #25 on: Tue, 17 November 2009, 14:03:38 »
The only Model M controller I have is an M5-2 controller, and that's in my keyboard!
Offline ch_123
« Reply #26 on: Tue, 17 November 2009, 14:34:54 »
What an odd place to keep such a thing!
« Reply #27 on: Tue, 17 November 2009, 14:37:01 »
It's just like keeping a floppy drive in a computer!
« Reply #28 on: Tue, 17 November 2009, 14:44:15 »
Quote from: microsoft windows;133307
You say that like it doesn't come out...
Offline itlnstln
« Reply #29 on: Tue, 17 November 2009, 14:51:37 »
Quote from: microsoft windows;133335
Like how my GF keeps my balls in a safe... wait.
Offline ch_123
« Reply #30 on: Tue, 17 November 2009, 15:14:20 »
That's a sure fire way to get a "Non Sytem Disk" error.
Offline SCTony
« Reply #31 on: Tue, 17 November 2009, 15:24:58 »
Shawn, are you at T.A.D.?
« Last Edit: Tue, 17 November 2009, 15:48:31 by SCTony »
IBM PC-AT Model F ;  Model M-
    1391401 Aug 89, 92G7453 Nov 95, 42H1292 Jul 97
Compaq KB-9963 (rubber dome);
Cherry MX-SPOS:typing:
« Reply #32 on: Tue, 17 November 2009, 15:42:08 »
Quote from: ch_123;133353
Only if there's no non-bootable floppy disk in the drive!
Offline itlnstln
« Reply #33 on: Tue, 17 November 2009, 15:50:19 »
Boot disks.  Good times, good times.
« Reply #34 on: Tue, 17 November 2009, 16:51:37 »
Quote from: SCTony;133358
You, sir, have some sort of sea service exposure (Marines or Navy). In the Army, it's TDY.
And, no, I'm home. I got back in February from Afghanistan.
Offline SCTony
« Reply #35 on: Tue, 17 November 2009, 16:53:40 »
LOL I was in  the Army and stationed there for a few years - 87,88,89. Quite a cushy assignment.
« Reply #36 on: Wed, 18 November 2009, 09:12:10 »
Oh, you said 'at' T.A.D., which means it's a location, not a status. I've never heard of it, where is it?
