Author Topic: Bluefruit LE Micro  (Read 2425 times)
Offline profet
Bluefruit LE Micro
« on: Tue, 17 November 2015, 14:18:09 »
I was thinking about building an Atreus keyboard but it seemed such a shame to have such a wonderfully compact keyboard that is burdened by a hardwired connection.
Has anyone successfully used the Bluefruit LE Micro as a keyboard controller?
Any success using TMK firmware?
Or is this uncharted territory?
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Offline neverused
Re: Bluefruit LE Micro
« Reply #1 on: Tue, 17 November 2015, 17:51:09 »
May be relevant:
Offline agbockus
Bluefruit LE Micro
« Reply #2 on: Thu, 19 November 2015, 21:05:19 »
It seems like this is a better alternative (mainly when building a custom without the PCB) than adding on to a controller. I'm not experienced with programming microcontrollers, but if it's built in then it shouldn't be too difficult. It would be awesome to find out, because I really want to make a custom HHKB layout that's Bluetooth with my Gateron Clears!
« Last Edit: Thu, 19 November 2015, 23:31:51 by agbockus »
