Author Topic: WASD Code PS2 Troubles  (Read 2654 times)
Offline kackburt
« on: Fri, 20 November 2015, 13:41:09 »
Got my new WASD Code keyboard today and have the following issue with it:
When using the PS2 adapter, my PC doesn't recognizes it. The keyboard blinks when booting, but not even the BIOS detects it.
USB works perfectly fine, but I'd like to use NKRO.
Strange enough, but when booting with another keyboard (Filco) via PS2, everythings normal and after booting I can also switch to the Code and then even the Code works via PS2... After a reboot it does not again!
Changing the PS2 adapter doesn't help.
Did a BIOS upgrade too, but that didn't help.
Any suggestions? Thanks in advance!
SteelSeries 7G, Cherry G80-3000HGD, Noppoo Choc Mini 84,Filco Ninja TKL, WASD Code
Microsoft 1.1 SE, SteelSeries Ikari, SteelSeries Xai, SteelSeries Sensei, SteelSeries KANA
Offline Homenubbie
Re: WASD Code PS2 Troubles
« Reply #1 on: Fri, 20 November 2015, 14:15:36 »
Does the keyboard specs say PS/2 support?
Not all do anymore.
Offline kackburt
« Reply #2 on: Fri, 20 November 2015, 14:35:01 »
Specifications say "Interface: USB / PS2"
Furthermore there is a PS/2 adapter inside the package "to access N-KRO or legacy systems"
Offline saturnotaku
« Reply #3 on: Fri, 20 November 2015, 14:54:06 »
Might want to fire off an email to WASD support. They're pretty good about responding within 24-48 hours.
Offline kackburt
« Reply #4 on: Fri, 20 November 2015, 15:07:24 »
thanks, did that - will report back as soon as I get an answer.
Offline daerid
    • Rossipedia
« Reply #5 on: Fri, 20 November 2015, 18:51:42 »
WASD support is incredibly awesome. They replaced a CODE board of mine that had it's backlight die after a nasty static shock. No questions, just shipped them the old board and the new one came a few days later.
Offline Waateva
« Reply #6 on: Fri, 20 November 2015, 22:01:32 »
I have heard great things about their support, another reason I picked up my V2.
Offline kackburt
« Reply #7 on: Sat, 21 November 2015, 14:23:04 »
they replied within a few hours...
told me that some motherboard/computer combo's don't work with PS2 and I should check another PC first.
will report back.
Offline Homenubbie
« Reply #8 on: Sat, 21 November 2015, 16:42:18 »
Please do.
What motherboard?
Offline kackburt
« Reply #9 on: Sun, 22 November 2015, 16:10:18 »
ASUS H87I
