Author Topic: KBP V60 case strengthen mod  (Read 2884 times)
Offline ctm
  • Hello, world!
« on: Sat, 21 November 2015, 15:02:08 »
I posted a thread asking about modding V60 case to make it more solid some days ago (more detail here). I decided to go with a simple and reversible one first. I bought some pieces of basswood and cut them with Dremel (first time using Dremel. It's such a awesome tool!). I then stick these pieces of wood to the case using double sided tape. The result is quite satisfying. Of course it's not as solid as aluminum case, but it's less bendy than before.
UPDATE: I tried some InstaMorph to patch the corners. It does not seem to have much effect. (Nonetheless, InstaMorph is an interesting material to play with  :) )
« Last Edit: Tue, 24 November 2015, 22:36:19 by ctm »
Coming:
Ellipse Model F F62.
Re: KBP V60 case strengthen mod
« Reply #1 on: Sat, 21 November 2015, 16:08:01 »
Good work, balsa is light so I guess this doesn't change the feel too much - just need to hope the tape holds.
Dremels are indeed awesome tools with so many uses but be careful of shattered cutting disks if you get the urge to cut anything harder :thumb:
Offline ctm
  • Hello, world!
« Reply #2 on: Sat, 21 November 2015, 16:51:21 »
Thanks! For next step I am thinking about getting some moldable plastic to fill in the gaps.
Coming:
Offline neverused
« Reply #3 on: Sat, 21 November 2015, 18:26:18 »
Sugru maybe useful for that.
Offline ctm
  • Hello, world!
« Reply #4 on: Sat, 21 November 2015, 20:14:02 »
If I remember correctly, Sugru is more flexible after cured. I just ordered some InstaMorph to have a try.
Coming:
Offline heedpantsnow
  • Old enough to know better
« Reply #5 on: Sat, 21 November 2015, 21:32:56 »
Cool man I like what you did
I'm back.
Offline ctm
  • Hello, world!
« Reply #6 on: Sat, 21 November 2015, 21:44:59 »
Coming:
Offline jaffers
« Reply #7 on: Tue, 24 November 2015, 06:40:11 »
Might do the same to my case if I get some spare time. Nice mod
