Author Topic: JTK Sophomore GB - 100% shipped - Form in OP for any missing or damaged keys  (Read 1560610 times)
Offline Captainbuttmonkey
Re: JTK Sophomore GB - 100% shipped
« Reply #2350 on: Thu, 16 March 2017, 17:02:18 »
I assume I'm too late for the orange/white set? No worries if so
not at all
im actually gonna post the form and all the info in about 3 mins
Wow, that's probably the best timing I have ever had for anything haha. Also I'm so glad you moved to the UK, nice to have cheap shipping and to not have to worry about customs =].
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #2351 on: Thu, 16 March 2017, 17:05:16 »
not at all
this is where im from good sir
« Reply #2352 on: Thu, 16 March 2017, 17:09:10 »
not at all
Oh my mistake, I thought you were Canadian for some reason =S whoops haha. Must be the politeness, easy to get the two confused  :p.
I've submitted my order, many thanks for running such a great service
Offline BunnyLake
  • X
« Reply #2353 on: Thu, 16 March 2017, 17:09:51 »
not at all
im a big fan of Canadians
byker is one of the nicest dudes i know
Offline BunnyLake
  • X
« Reply #2354 on: Thu, 16 March 2017, 17:18:33 »
Done another full sweep on support, these are the last 8 packages of faulty or missing keys that need to go out and are being dropped off tomorrow, after this all that is left by way of replacements are the few keys I needed to request from jtk and the handful of replacements that need keys from the orange mod set
These shipped to me yesterday with the sliders
Offline Vigrith
« Reply #2355 on: Thu, 16 March 2017, 17:27:44 »
Quick question, when you mentioned the prices of the base set and mods for the white/orange set last page, is the $65 price for the entirety of the base sets (including orange on white mods) and then the mods you mentioned for $35 are the white on orange "accents", correct? Sorry if this is obvious.
Offline BunnyLake
  • X
« Reply #2356 on: Thu, 16 March 2017, 17:31:48 »
so for 65 you get an entire base set, that is a full set of orange on white keys, then there is an option for the additional mods with white on orange,
if you check the black and orange set and add on here
https://ctrlalt.io/buys/jtk-sophomore
its exactly the same but replace the black with white
there are also a few additional keys not shown in that mockup
Offline Vigrith
« Reply #2357 on: Thu, 16 March 2017, 17:35:33 »
I figured that was the case, I ordered the pink/black which has no extra mods hence I was asking for clarification. Thanks! Probably order one tomorrow, the white on orange mods look really cool from that picture you showed prev page.
Offline BunnyLake
  • X
« Reply #2358 on: Thu, 16 March 2017, 17:46:50 »
yeah the contrast is better than i expected when jtk told me he had made them, i think they came out really nice
he had some excess material left of the 2 colours so did the sets whilst he was making some additionals of the last colours recently
Offline schoolbus
« Reply #2359 on: Thu, 16 March 2017, 20:54:00 »
j/w am I a part of this?:)
Offline Theachromatic
  • HHKB
« Reply #2360 on: Fri, 17 March 2017, 16:23:58 »
Bunny, are you going to give us tracking for the JTK sliders individually or in a spreadsheet?
Offline chuckdee
« Reply #2361 on: Fri, 17 March 2017, 16:43:35 »
Are these in stock now?  Or being shipped?  Just wondering since I was waiting on the Black on Orange Mods, if they'd be in the same order if I placed one today.
Offline BunnyLake
  • X
« Reply #2362 on: Fri, 17 March 2017, 16:45:45 »
They are ready and on hand with jtk, I'll be ordering with him Wednesday and he would ship them basically immediately after
So they would be about 6 days behind the other extras that left to me on either Wednesday or Thursday, so I could combine if you wanted and would not change timeline much
Offline BunnyLake
  • X
« Reply #2363 on: Fri, 17 March 2017, 16:46:24 »
I'll be updating the tickets tomorrow night
Offline Latin00032
« Reply #2364 on: Fri, 17 March 2017, 17:38:13 »
Also, someone on r/MK said this:
ATTENTION:
I talked with the maker before, the switch of shift and enter keys are not the same as the one in Novatouch.
For this one, there is no stabilizer, but only a MX port.
For Novatouch, there is a stabilizer, you can drill a hole on your HHKB/Realforce to support the shift/enter key.
Therefore, if you use this one to replace your shift/enter key, the keycap will be stuck after you press it down, because of no stabilizer.
Would this be something we would have to think about, even if we did modify the stems on our stabilized keys?
i have no idea what they are talking about or referring to
i have extensively tested the sliders and they do indeed come with stabilsed sliders and worked perfectly for me
edit - the only issue at all i found with the stabilsers is some keys had a very slight clearance issue, they would function perfectly, so no sticking whatsoever, but were maybe a mm higher than the other keys of that row
for keys i had that issue with, i didnt drill my case at all, but i removed a very small amount of material from the 2 stabilised sections of the caps, its very minimal and if anyone is interesting ill document me doing it when the new sets arrive, this wasnt an issue in all sets i tried, but the ones that did present a slight clearance issue, it was very easily resolved and the amount of material i needed to remove was so small the caps still functioned perfectly again on mx stabs
but i have tried SA, oem, dcs, gmk, dsa, jtk on these sliders, and havent had a need to drill my case in anyway whatsoever and have full functionality of those keys and all profiles at the appropriate height (with in some limited occasions about 30 seconds of work on the bottom of the caps)
Id like to see pics on what would need to be done.
Offline BunnyLake
  • X
« Reply #2365 on: Fri, 17 March 2017, 18:01:36 »
ATTENTION:
with caps i care about i very neatly sanded away the very small amount of material, with caps i didnt i just snipped them, but when the new sliders arrive ill do a full write up with pics etc
Offline Latin00032
« Reply #2366 on: Fri, 17 March 2017, 20:46:49 »
ATTENTION:
Cool! Thanks
Offline MvanDiemen
  • Click-clack-woohoo :D
« Reply #2367 on: Sat, 18 March 2017, 02:03:08 »
Just to be sure, I filled in the JTK Sliders form on 30. november, do I need to fill in the confirmation form which is now in the OP or not?
Offline BunnyLake
  • X
« Reply #2368 on: Sat, 18 March 2017, 08:19:59 »
Should be the same form sir
Offline TheBestUkester
« Reply #2369 on: Sat, 18 March 2017, 14:41:41 »
If this needs to be a support ticket or whatever, lemme know, but could I change the color out on sliders at this point?
Offline BunnyLake
  • X
« Reply #2370 on: Sat, 18 March 2017, 15:33:24 »
Shoot tym a message he should be able to amend the form for you
Offline BunnyLake
  • X
« Reply #2371 on: Sun, 19 March 2017, 16:01:02 »
All invoices sent for the orange and white set
Here is a picture of it combined with the additional mods
« Reply #2372 on: Sun, 19 March 2017, 16:03:39 »
Paid, set looks awesome =]
Offline BunnyLake
  • X
« Reply #2373 on: Sun, 19 March 2017, 16:04:46 »
ill have better pics soon, he was too busy actually sorting it and sending out my sliders etc but once i get nicer pics ill post them
Offline Vigrith
« Reply #2374 on: Sun, 19 March 2017, 18:13:46 »
Was there any work done to the legends in the interim between the original sets and this one by any chance? They look perfectly uniform there whilst there were tiny discrepancies in the earlier ones people received of the "regular" sets.
This is not a critique by any means, I have no issue with the things I've seen of the others, I'm just pleasantly surprised and expectant for the future because of how solid those look from that particular picture.
Offline BunnyLake
  • X
« Reply #2375 on: Sun, 19 March 2017, 18:30:06 »
I haven't had these on hand yet myself so I don't actually know if the recent changes were done pre or post this set being run off, what I do know for a fact is multiple legends have already been fixed and more are being done before the next the launch
I'm not entirely sure how the timeline was between running this off with the extra material he had or changing the moulds but I'll find out shortly
I have know jtk for many many years and I can say with certainty he will not rest until he gets these sets perfect and is constantly working towards that goal
Offline Koobs
« Reply #2376 on: Mon, 20 March 2017, 12:55:08 »
Is that form for the JTK Debut as well or just for sophomore? I filled it out but I bought the JTK Debut a while ago. Thanks!
Offline BunnyLake
  • X
« Reply #2377 on: Mon, 20 March 2017, 15:16:56 »
are you referring to the slider form
if so then yes its for anyone who ordered sliders to fill out to confirm colour preference and current address
Offline Unforgivable
« Reply #2378 on: Mon, 20 March 2017, 15:37:04 »
Silly question Bunny, but do you still have any BoW or PoW sets left over?
Offline BunnyLake
  • X
« Reply #2379 on: Mon, 20 March 2017, 15:38:56 »
i think i have a couple but all packed up right now so best to ask me in a month or so once im all completely finished with all slider shipping and gh60 stuff etc and have a bit more space to work with
« Reply #2380 on: Mon, 20 March 2017, 15:43:06 »
Woot! I can wait. Some website had limited BoW stock, but I much rather get the sets from you. Thank you, sir!
Offline Vadurr
  • Valar Morghulis
« Reply #2381 on: Mon, 20 March 2017, 20:23:48 »
When can we expect the sliders to start shipping out? :]
Offline Glissant
« Reply #2382 on: Mon, 20 March 2017, 20:35:35 »
This is the latest about the sliders that says anything about approximates. I think.
quick update guys,
sliders have now shipped to me, well, technically they are shipping to me today china time but tomorrow my time or something like that
essentially ill have tracking tomorrow but was told this morning they were shipping to me tomorrow morning china time and its now evening my time and almost morning time there
anyway enough confusion
they are on the way
also ive just been through and updated a bunch of support tickets, and will try and get some more done later tonight
thanks for everyones patience in replies , im getting there
Thanks for the updates, cant wait to have my mods and sliders in hand ! Keep up the great work bunny!
no problem good sir
id estimate they will arrive late next week, if not very early the following week depending on how customs etc treats me but ill be sure to keep everyone informed of the package progress here
once they arrive i have 6-8 support requests to fullfill of missing stuff i needed jtk to replace so that will be done immediately
then ill set about packing up all the sliders
im fairly confident i can have all slider orders complete within a week of them arriving but i will say within 2 weeks just so i dont end up disappointing people with timelines as there are a ton of them
Offline Vadurr
  • Valar Morghulis
« Reply #2383 on: Mon, 20 March 2017, 21:38:06 »
Sweet thanks!!!
Offline BunnyLake
  • X
« Reply #2384 on: Tue, 21 March 2017, 01:36:55 »
Thanks glissant for the quote
That info is still accurate, sliders are on the way next update regarding those will be when they arrive
Can't wait
Offline n__dles
« Reply #2385 on: Tue, 21 March 2017, 06:20:13 »
Hey Bunny, not to be difficult, but since I'm still waiting on Orange & Black + Black on Orange mods, would it be possible to drop the Black on Orange mods and just have the Orange & Black shipped now?
Offline BunnyLake
  • X
« Reply #2386 on: Tue, 21 March 2017, 07:32:55 »
You can but the mods will be on hand in a few days, Im expecting them late this week
Offline n__dles
« Reply #2387 on: Tue, 21 March 2017, 08:49:29 »
Getting impatient with a new build waiting for caps. Not planning on using the mods on it, they were for maybe one day / just in case.
What do I need to do to drop the mods from my order? Through the website, PM?
Offline BunnyLake
  • X
« Reply #2388 on: Tue, 21 March 2017, 08:54:13 »
Just open or amend your support ticket but to make you aware the earliest I will be able to ship again is probably Saturday
Offline Koobs
« Reply #2389 on: Tue, 21 March 2017, 10:24:50 »
Awesome, thanks for the reply!
Offline BunnyLake
  • X
« Reply #2390 on: Tue, 21 March 2017, 15:46:54 »
if anyone has a support ticket regarding missing keys, replacements, order issues at all that you believe is in need of action or a reply from me about this gb
please could you pm me your ticket number and ill will get to it right away, im about to go through a ton of support stuff now but i want to make sure nothing is left out and everyone gets sorted
so if anyone is waiting on a response and hasnt got one, please dont let it drag on or get lost out of not wanting to bother me, hit me up via pm with the ticket number and ill get on it right away
thanks
Offline Dadrophenia
« Reply #2391 on: Tue, 21 March 2017, 17:32:28 »
thanks
Thanks Bunny, sent a PM about this!
« Reply #2392 on: Tue, 21 March 2017, 21:06:52 »
thanks
I keep meaning to reply to say thanks for the update on my ticket, BunnyLake, and i'll look forward to receiving the goods in due course :)
Offline BunnyLake
  • X
« Reply #2393 on: Thu, 23 March 2017, 02:54:16 »
Sliders have arrived
I have my son all day but tonight I'll take pictures, post updates and start packing
I would expect to have the first 200 or so sets out the door tomorrow morning
Offline Dyaems
« Reply #2394 on: Thu, 23 March 2017, 03:05:05 »
yeeeeeee
   B.face X2
  65g Zealios
« Reply #2395 on: Thu, 23 March 2017, 05:46:50 »
Offline nsmechkb
« Reply #2396 on: Thu, 23 March 2017, 05:55:32 »
So excited!  Thanks, Bunny!
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #2397 on: Thu, 23 March 2017, 08:30:58 »
Bought some thick krytox lube mix and I'll be ordering some silencing rings soon, gotta do everything while I have my board taken apart!
Really excited to get these, thanks for the hard work bunny.  :-*
Offline briannnn
« Reply #2398 on: Thu, 23 March 2017, 09:22:32 »
Don't know if I'm allowed to ask this here at this point, but if anyone is willing to part with a set of sliders or if there's any other way to get a set, I'd really love to hear about it.
Offline BunnyLake
  • X
« Reply #2399 on: Thu, 23 March 2017, 09:32:16 »
Just shoot me a dm and I can hook you up sir
