Author Topic: New Pok3r Backlit  (Read 16361 times)
Offline droshi
New Pok3r Backlit
« on: Sat, 21 November 2015, 19:59:26 »
Has anyone gotten one yet?
I'm seeing it here, looks available:
http://www.amazon.com/Mechanical-Keyboard-coating-Keycaps-Mx-Clear/dp/B014T4PK0M/
Trying to decide if it's worth it over the regular pok3r with stock PBT caps.
ABS dual coating means just regular ABS caps with a coating over them right? Or is it real-double shot caps?
Offline cryptokey
  • [°°▄°] luser-friendly
Re: New Pok3r Backlit
« Reply #1 on: Sat, 21 November 2015, 20:12:45 »
Wow, that's pricey.  I'm currently in the process of LED modding my POK3R and so far I've got a few LED's installed and working  :thumb:  Personally, I LOVE the stock keycaps on the regular POK3R.  The sound and feels are wonderful!
[WTB] HHKB Black
Offline droshi
« Reply #2 on: Sat, 21 November 2015, 20:14:17 »
Wow, that's pricey.  I'm currently in the process of LED modding my POK3R and so far I've got a few LED's installed and working  :thumb:  Personally, I LOVE the stock keycaps on the regular POK3R.  The sound and feels are  :eek:
$130 vs 150 didn't sound like much of a price bump, I'm comparing both versions with MX clears, maybe other switches are a little cheaper?
Offline cryptokey
« Reply #3 on: Sat, 21 November 2015, 20:46:21 »
For me, the link showed Amazon.ca for $220CAD + shipping.  It must have changed from my Canadian IP
[WTB] HHKB Black
Offline mrboovn
« Reply #4 on: Sat, 21 November 2015, 22:40:33 »
Same here.Decided to added LEDs for my Pok3r brown because i love the feel of the old :D
Offline lunas
« Reply #5 on: Sun, 22 November 2015, 22:04:45 »
Any issues with buzzing on an LED mod? I've heard a couple of reports of buzzing at full brightness.
If you have to buy gear for a self-install it seems like buying backlit is worth it. I agree with cryptokey though. I really like the stock pbt caps on my white pok3r.
Pok3r Whitefox
Offline swimmingbird
  • keyset hoarder
« Reply #6 on: Sun, 22 November 2015, 22:08:46 »
The stock poker keycaps are really not bad - the ones on the backlit model look pretty awful though
Offline cryptokey
« Reply #7 on: Sun, 22 November 2015, 22:20:16 »
If I adjust the brightness too much, then the lights go off and the red led under the spacebar goes on.  No buzzing.  I then just turn down the lighting and wait a bit or unplug/plug it back in. I'm using the most recent firmware.  Perhaps updating would solve that issue for some people.
Yeah I personally really enjoy the feel and sound of stock pok3r caps - minus how easily they get dirty.
« Last Edit: Sun, 22 November 2015, 22:41:14 by cryptokey »
[WTB] HHKB Black
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #8 on: Sun, 22 November 2015, 22:33:42 »
Those keycaps are fugly...but atleast it has MX Clears.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline droshi
« Reply #9 on: Sun, 22 November 2015, 23:58:50 »
The backlit ones? Judging by the pictures or has anyone yet seen them in person? In Pictures a lot of backlit boards I could see look bad. But I bet it's more to do with lighting and camera than the board.
Offline trenzafeeds
  • **** off
« Reply #10 on: Mon, 23 November 2015, 04:57:23 »
Wow so that's not worth it. LED mod is extremely easy and cheap.
demik will never leave.
Unless he gets banned.
Offline droshi
« Reply #11 on: Mon, 23 November 2015, 09:48:33 »
Really? For $20 you can install LEDs on the old Pok3r and new keycaps? Of course discounting time and errors.
I can't decide which I'd like to get, but it seems most people are voicing odd concerns to justify the old Pok3r.
I thought it would be really more a debate of laser engraved PBT vs how good the new ABS caps are. According to here they are doubleshot:
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1418
I've seen a lot of reports that the original stock PBT cap legends fade very quickly, so I'm guessing neither are perfect.
I've seen some good custom caps in other threads, but could never figure out, is anyone producing custom caps specifically for the Pok3r with the Fn layer printed as well?
Offline trenzafeeds
  • **** off
« Reply #12 on: Mon, 23 November 2015, 10:06:09 »
A pok3r should be around $110 if you look around, and LEDs cost like maaaybe $5. There shouldn't be any errors installing  LEDs, it's literally so easy.
Offline Homenubbie
« Reply #13 on: Mon, 23 November 2015, 10:17:25 »
Ack! I just bought the non-backlit!
 :-X
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #14 on: Mon, 23 November 2015, 10:53:20 »
I know there have been a lot of delays with the LED version of the Pok3r. Has anyone seen a working version?
The video they posted on their Facebook page shows multi-color LEDs cycling through, but what I'm seeing on MK.com is just white.  :confused:
Offline droshi
« Reply #15 on: Mon, 23 November 2015, 11:14:54 »
From what I've heard the first run is white LED, next run will be blue or some other solid color, 3rd run will be the multi-color they showed on their facebook page.
It looks like the white LED version is just coming out, and I guess not many people have ordered or gotten theirs yet. So as a guess it's probably a while before the multi-colored ones come out.
They also announced development of a Poker 4 that splits in half, but I guess that's probably even further from coming out.
Offline cryptokey
« Reply #16 on: Mon, 23 November 2015, 11:34:29 »
In the updated Pok3r manual, it shows RGB controls so it's definitely compatible with rgb lighting
[WTB] HHKB Black
Offline mashby
    • Mashby
« Reply #17 on: Mon, 23 November 2015, 11:54:48 »
Just getting back into the swing of all things keyboards, so pardon my newbie question...
Any idea what LEDs are going to be used in the RGB version? Is this the four pin LEDs, or something different?
Offline Homenubbie
« Reply #18 on: Mon, 23 November 2015, 13:46:30 »
When will the RGB Pok3r come out?
Offline phosphoric
« Reply #19 on: Mon, 23 November 2015, 14:48:02 »
 :-X
no worries. order some leds from colorfulplace888's ebay page, solder them in, and you'll be golden
i was under the impression that rgb leds were exclusively 4-pin? but i could be wrong
Let's get this straight. There is nothing cool about keyboards we're all lame as fk.
speak for yourself
Offline dutC4
« Reply #20 on: Mon, 23 November 2015, 14:50:27 »
I can't believe it took so long for them to put out the backlit version. Here I was thinking an RGB version would be out by now..
Offline mashby
    • Mashby
« Reply #21 on: Mon, 23 November 2015, 15:06:53 »
I heard they had some issues with the firmware. I don't know it's related to RGB or not, but that's why I opted to hold out until the backlit versions shipped.
Offline cryptokey
« Reply #22 on: Mon, 23 November 2015, 15:28:41 »
 :-X
Although there are 4-pin ones, 2-pin RGB LEDs exist as well.  Queue 2-pin RGB LED Dubstep video :cool:
https://www.youtube.com/watch?v=gxyaSJNJgjA
« Last Edit: Mon, 23 November 2015, 15:31:52 by cryptokey »
[WTB] HHKB Black
Offline phosphoric
« Reply #23 on: Mon, 23 November 2015, 17:04:16 »
 :-X
holy jesus... are you telling me my recent order of 100 white leds was a mistake? :(
just kidding. i think rgb is excessively flashy anyway. i like the simplicity of white leds. do you know if it's possible to swap out the stock red/blue leds with white ones? even though i won't get the same indicators, i don't mind. i just want uniformity  ;D
speak for yourself
Offline droshi
« Reply #24 on: Mon, 23 November 2015, 17:40:24 »
I think I'm about set to go with the non-backlit Pok3r. Although some conflicting pictures, most seem to indicate that the backlit version won't have the Fn layer legends on the sides of the keys. This would be my first 60% board, so I'm pretty sure I'll need that to get used to things. For me, the backlighting was just an occasional thing in a dim lit room, and mostly I envisioned using it as a reference to the Fn layer. So overall I think it would be relatively useless for me.
Now to just decide white vs black. Normally I'd go with black to match pretty much everything else, but the Pok3r black keys seem a bit more charcoal, and the white looks pretty nice. Other than initial looks, is there any problems with white yellowing over time on these boards? Or pretty much a non-issue these days?
Offline phosphoric
« Reply #25 on: Mon, 23 November 2015, 18:51:12 »
it's painted aluminum so you should be good re yellowing
speak for yourself
Offline droshi
« Reply #26 on: Mon, 23 November 2015, 19:17:28 »
Thanks, was thinking about the caps, but realized they are PBT, and shouldn't have issues either.
Still if anyone gets a backlit pok3r, please post here. I knew it was released not that long ago, but thought someone would have had one on here by now.
Offline mashby
    • Mashby
« Reply #27 on: Tue, 24 November 2015, 13:12:53 »
And that probably explains the delay. I have a few RGB LEDs I got from Sprit and in my testing they simply cycle through all the colors. I would imagine that the PCB has to allow for changes in voltage to distinguish specific colors, maybe?
Curious to see what the finished product looks like, but I'm going to wait until the RGB are available.
Offline file_id
« Reply #28 on: Wed, 25 November 2015, 22:17:38 »
So I got the new backlit pok3r. My initial review is the new backlit version is better than the pok3r when they initially came out. The pbt keycaps that came with the nonbacklit version fade really quick and aren't as good as the pbt keycaps that come with the poker 2. Secondly, it seems that the pok3r with backlit come with a new aluminum case. The case is painted better, the texture, and the case is redesigned and doesn't have the plastic tray anymore when the pok3rs first came out.
Original pok3r case
New Cases with the pok3r
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
Offline ideus
  • Björkö.
« Reply #29 on: Wed, 25 November 2015, 23:20:49 »
Even with my limited DIY skills, I'd get a custom, over this stock keyboard, any day.
Offline cryptokey
« Reply #30 on: Wed, 25 November 2015, 23:32:28 »
I've got the newer version of the pok3r (non-backlit) and it definitely has the same case as the pok3r backlit.  Upon taking it apart, it doesn't have the plastic tray either.
By now, I've already installed LED's in my pok3r and updated the firmware with no issues.  The only thing I had trouble with was one LED that was completely related to my noob soldering skills.
« Last Edit: Wed, 25 November 2015, 23:35:56 by cryptokey »
[WTB] HHKB Black
Offline cryptokey
« Reply #31 on: Wed, 25 November 2015, 23:37:15 »
Yeah, good idea.  Once the firmware update is available when the RGB version comes out, then it'll probably be safe to upgrade and install RGB.
[WTB] HHKB Black
Offline file_id
« Reply #32 on: Thu, 26 November 2015, 00:45:28 »
I was under the impression that the new Cherry MX RGB would be in the RGBs Pok3rs when they come out or is that not the case?
Offline droshi
« Reply #33 on: Thu, 26 November 2015, 23:27:21 »
Looks like a drop is up with blue LEDs...PBT caps optional too
https://www.massdrop.com/buy/vortex-pok3r-backlit-compact-keyboard
Looks better in these photos than others I've seen yet.
« Last Edit: Thu, 26 November 2015, 23:29:26 by droshi »
Offline Kliwon
« Reply #34 on: Sun, 29 November 2015, 18:35:36 »
Take non backlight POK3R, and wait 40% vortex..
Offline OFred
« Reply #35 on: Thu, 17 December 2015, 14:06:01 »
Hello,
I managed to put temporarily one LED and it worked fine.
I played also with the caps lock Led, this one seems to be a dual led color like under the space bar.
So is it possible to change the color of this light ? I tried FN + Q but ...nothing.
Fred
Offline Zorox
  • Tactile FTW <3
« Reply #36 on: Thu, 17 December 2015, 15:14:59 »
Vortex has recently announced a RGB backlit version of Pok3r, so my advice for you is to calm down and wait for it :D
Offline OFred
« Reply #37 on: Sat, 19 December 2015, 04:11:11 »
No  :p
I don't need a RGB one.
Just would like to play with my current pok3r.
As there's a dual color led i m just wondering how to change the color, hope that's possible.
Offline Kliwon
« Reply #38 on: Sat, 19 December 2015, 06:01:19 »
may I ask, what colour stabilizers POK3R with backlight versions? still orange?
Offline tronbeaver
« Reply #39 on: Sat, 19 December 2015, 09:27:29 »
My next keyboard!
