Author Topic: DCS 6u Space bar stems  (Read 3589 times)
Offline keshley
    • Blog n stuff
« on: Mon, 23 November 2015, 07:40:26 »
Having some trouble finding the stem placement for DCS 6u space bars, can anybody shed some light?
I know Cherry profile 6u space bars are 95mm center to center for the stabilizers, and off-center for the central stem, but some 6u space bars are 98mm center to center, some are off-center for the central stem, and some are not.
So if anybody can shed light on the DCS profile 6u space bar stem placement, that would be awesome!
HHKB Pro 2       Pok3r
Re: DCS 6u Space bar stems
« Reply #1 on: Mon, 23 November 2015, 08:17:46 »
I don't have a DCS 6u spacebar, so I don't know for sure what the stem dimensions are. But SP's DSA 6u spacebar are 76mm center-to-center, with a centered switch stem. My guess would be that the DCS stem placement would be the same, but again, I have no way to verify that.
Offline keshley
    • Blog n stuff
« Reply #2 on: Mon, 23 November 2015, 08:32:52 »
76mm is a lot narrower than I was expecting. I'd expect the placement to be the same too. Thanks jd!
HHKB Pro 2       Pok3r
