Author Topic: Lubing MX Clears  (Read 1596 times)
Offline hKing
  • I am ze Ubermensch!
Lubing MX Clears
« on: Mon, 23 November 2015, 10:38:02 »
Hi there guys,
I am planning to lube my Pok3r with mx clears.
Can you recommend me a lube?
Thanks in advance!
Offline jerue
  • (Whenever that happens :P)
Re: Lubing MX Clears
« Reply #1 on: Mon, 23 November 2015, 18:24:48 »
I bought some Geekhackers V3 lube with my Zealio purchase, it's a nice mix. I recommend.
http://zealpc.net/collections/accessories/products/ghlube
Offline jamster
« Reply #2 on: Mon, 23 November 2015, 20:15:28 »
I used Mechlube 2 from Elite Keyboards.
Though if you're going to go to the not inconsiderable effort of desoldering and taking apart all your switches, you may as well consider swapping in lighter springs.
