Author Topic: My new keyboard came in today!  (Read 7000 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« on: Mon, 16 November 2009, 17:28:23 »
You guys won't believe this, but I actually PAID MONEY FOR A KEYBOARD. It's a Focus FK-9000 keyboard from the early 1990's with an integrated calculator.
I got it in the mail today. The guy took a lot of care into packing it; it can in huge box filled with so many packing peanuts I could fill a big garbage bag with them.
I took out the keyboard. It's got some neat features. First off, it's got red indicator lights built into the lock keys. Its keycaps also have multi-colored captions and are dual-shot as well! It's also got white Alps switches. Even better, it works!
Offline ch_123
« Reply #1 on: Mon, 16 November 2009, 17:30:20 »
Does the LCD operate properly? Apparently this is a common point of failure on those boards.
« Last Edit: Mon, 16 November 2009, 17:32:49 by ch_123 »
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #2 on: Mon, 16 November 2009, 17:54:57 »
Awesome find! Mind telling how much you paid for it?
I worked for a PC shop about 15 years ago, we sold a lot of Focus KB's. They ranged from $45-$65 depending on which model you went with, i.e. 2000, 5000, 6000 or 8500 if I remember correctly. They are great KB's and I'd love to have another one.
I just received my Filco 87 key with Cherry browns which is really nice too. :nerd:
« Reply #3 on: Mon, 16 November 2009, 18:03:08 »
I paid about $20 for it.
About the calculator, the PCB is dirty and probably needs a cleaning which explains why the LCD is acting a little flooky.
Offline msiegel
« Reply #4 on: Mon, 16 November 2009, 18:08:27 »
Quote from: microsoft windows;133016
heh heh, even *you're* not immune to the keyboard buying bug XD
that's quite a deluxe board... even has air conditioning, according to the keycaps ;)
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/29410/subcatid/0/id/406362
« Reply #5 on: Mon, 16 November 2009, 19:25:02 »
I cleaned mine up and it's working fine except the calculator's LCD is a little flooky. It's probably a bad connection in its filthy mainboard. Mine's quite a lot older than the broken one at ClickyKeyboards; it was made in 1989!
In order to test it, though, I had to dig up the "old" computer (Yes, I mean dig up, there's that much junk.) since it was the only one with an old-fashioned AT-DIN port to test it on. I'm going to purchase a cheap little DIN-Mini Din adapter off Ebay soon and use it on one of my desktops (the one without the Model M).
Stay tuned for some blurry photos and a documentary on what caused the calculator to malfunction.
« Last Edit: Mon, 16 November 2009, 19:28:24 by microsoft windows »
« Reply #6 on: Mon, 16 November 2009, 20:33:04 »
Here are some pictures of the keyboard.
You can see these keys are double-shot without chopping them to bits.
I like the red indicator lights too. They and the wacked-out calculator add a little touch to this keyboard...
Offline AndrewZorn
« Reply #7 on: Mon, 16 November 2009, 21:08:17 »
the calculator is hilarious
Offline hyperlinked
« Reply #8 on: Mon, 16 November 2009, 21:13:38 »
Quote from: AndrewZorn;133077
It needs a built in lighter.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline SCTony
« Reply #9 on: Mon, 16 November 2009, 21:34:55 »
LOL You crack me up Microsoft Windows.
"You can see these keys are double-shot without chopping them to bits."
IBM PC-AT Model F ;  Model M-
    1391401 Aug 89, 92G7453 Nov 95, 42H1292 Jul 97
Compaq KB-9963 (rubber dome);
Cherry MX-SPOS:typing:
« Reply #10 on: Tue, 17 November 2009, 13:51:00 »
How do you tell whether or not it is the original white ALPS?
Offline itlnstln
« Reply #11 on: Tue, 17 November 2009, 14:09:36 »
Complicated switches were only made by ALPS.  Generally, if you see "ALPS" on the top of the case of the switch, it is genuine (not always, but usually).  Something of that vintage is going to have the real deal.  Usually, you only see copies on newer keyboards.
Offline sixty
    • http://deskthority.net
« Reply #12 on: Tue, 17 November 2009, 14:12:36 »
Quote from: itlnstln;133311
Actually most of the complicated old real alps (or whatever the hell they are called!) do not have a logo at the top of the case, only at the bottom. The same goes for the older blue sliders (which are identical to the old genuie complica... damn it, the good alps).
Offline itlnstln
« Reply #13 on: Tue, 17 November 2009, 14:19:33 »
Quote from: sixty;133315
True, I wasn't very clear about this, but I wouldn't go desoldering switches just to check.
« Reply #14 on: Tue, 17 November 2009, 14:30:35 »
I took a look at a switch and it's got the Alps logo. However, the yellow switches on the lock keys which have LEDS do not. But they've got to be genuine Alps since all the others (the white ones) are. There's also another flavor of the white ALPS on on key which switches between calculator and number-pad mode. This key is locked down when in calculator mode until it is pressed, which brings it back into number-pad mode. This one switch does not have the ALPS logo.
Here's the "lock-down" white ALPS switch. Note the little white part under the switch.
Here's the Caps-Lock key with the indicator lighted up.
Here are the keyswitches for the Caps-Lock and Tab keys. The Tab one, like the others other than the lock keys and the "lock-down" key, is an original White Alps. However, the Caps Lock is a Yellow Alps with an LED.
« Reply #15 on: Tue, 17 November 2009, 14:54:47 »
I took a trip to the Alps wiki but all the URLS about the simplified ALPS resulted in Err 404 Not Found's. Guess those URLS have gone bad.
This keyboard was manufactured in November 1989. Do you know if they made simplified ALPS at the time?
About the feel of those keys, I'd say they feel the opposite of stiff. They click loudly but are very smooth and require much less force to depress a key and record a keystroke than an IBM.
Here's a picture I drew on my computer of one of the white switches.
You  can see the logo is below the switch.
Offline itlnstln
« Reply #16 on: Tue, 17 November 2009, 14:57:23 »
You've got the real deal, microsoft, I wouldn't worry about it.  ALPS are lighter than BS by about 10g, or so.  I'm glad you're enjoying the 'board.
« Reply #17 on: Tue, 17 November 2009, 15:40:57 »
It's a great keyboard. Now I just have to get a DIN-PS/2 adapter so I can use this on a computer better than the one with Wndows 3.1.
Offline ocdonkb
« Reply #18 on: Tue, 17 November 2009, 16:59:38 »
Quote from: microsoft windows;133366
heh, I was just looking for the same thing. I think this what you need:
http://www.cablestogo.com/product.asp?cat_id=104&sku=02476
Assuming your keyboard has a 5 DIN male connector coming out... this adapter will convert from 5 DIN female to PS/2 male.
Note that the picture on that website is wrong. It's showing the AT male to PS/2 female connector - opposite of what you need.
« Last Edit: Tue, 17 November 2009, 17:01:40 by ocdonkb »
| Filco Brown 87 key | Realforce 87U | Unicomp Spacesaver | IBM Model M | Cherry ML4100 | Dell AT101W | Focus 2001 |
« Reply #19 on: Tue, 17 November 2009, 17:11:00 »
I found on Ebay that's a little cheaper.
« Reply #20 on: Tue, 17 November 2009, 18:09:46 »
These keyswitches definitely feel much less stiff than the Model M. It takes virtually no effort (at least by my standard but I have been using a Model M for a long time) to type on the thing. Now I see (or feel) why people go crazy over those Omnikeys.
If only I had something better than an ancient cell-phone camera I'd make a wiki about these Focus keyboards.
« Reply #21 on: Tue, 17 November 2009, 19:36:47 »
Those Japanese sites drive me nuts. They've probably got interesting stuff, but it's all in a wildly different language!
Offline itlnstln
« Reply #22 on: Wed, 18 November 2009, 08:06:16 »
Quote from: ripster;133464
Guess what they say about Geekhack?
I could only imagine, ripster.
« Reply #23 on: Wed, 18 November 2009, 15:42:34 »
I have no idea. Probably something like "Geekhack keyboard people English speaking" if it went through through the Google translator.
« Reply #24 on: Wed, 18 November 2009, 17:49:43 »
I opened up the Focus FK9000 to clean up the calculator and I noticed that the motherboard was full of a white residue similar to leaky batteries. I cleaned it up. Stay tuned for more information coming up!
Offline InSanCen
« Reply #25 on: Wed, 18 November 2009, 17:53:52 »
Quote from: ripster;133882
If you are talking around the controller it sounds like blown caps to me.
This.
Grab some low ESR's from digikey/mouser/maplin/farnell/RS and break out the Iron.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
« Reply #26 on: Wed, 18 November 2009, 19:02:49 »
I cleaned out the circut-board and it behaves similarly. I think there is an issue with the LCD controller.
« Reply #27 on: Wed, 18 November 2009, 19:20:13 »
Doesn't look like most of the pictures are working. But took a good look at the calculator's PCB and the capacitors are just fine. I think there's an issue with the LCD controller instead as it looks like the rest works fine.
« Reply #28 on: Wed, 18 November 2009, 19:34:34 »
Is the bulging at the top obvious?
« Reply #29 on: Wed, 18 November 2009, 19:44:27 »
The capacitor on the calculator's mainboard appears to be fine then. I'm really starting to think it's the LCD controller as when I press a key, the LCD reacts.
