Author Topic: PS/2 Combiner to USB?  (Read 1330 times)
Offline trenzafeeds
  • **** off
« on: Thu, 26 November 2015, 20:22:02 »
I recently purchased an ATC board, which has a double-PS/2 cable, one for the trackpad and one for the keyboard. I had intended on only using the keyboard one, as my PC has only one PS/2 input, but I was wondering if there exists some sort of PS/2 to usb converter that could combine these two into one usb input.
demik will never leave.
Unless he gets banned.
Offline njbair
    • nickbair.net
Re: PS/2 Combiner to USB?
« Reply #1 on: Thu, 26 November 2015, 20:25:37 »
I have one of these, works great even with my oldest boards:
TRENDnet USB 1.1 to PS/2 Converter, TU-PS2 https://www.amazon.com/dp/B0007T27HI/ref=cm_sw_r_other_awd_L77vwbG2AXBX0
My boards:
Offline trenzafeeds
  • **** off
« Reply #2 on: Thu, 26 November 2015, 20:28:48 »
Wow, this is exactly what I was looking for! Thanks!
Offline SamirD
« Reply #3 on: Fri, 27 November 2015, 14:42:00 »
I have a Belkin one and one thing I've observed when connecting an M with the integrated trackpoint is that only one of the connectors needs to be connected for both the trackpoint and the keyboard to work.  It actually won't work if I connect both.  So you'll maybe want to experiment a bit too.
