Author Topic: Typing on mx browns: indistinguishable from mx reds?  (Read 2617 times)
Offline macguy80
« on: Thu, 26 November 2015, 22:55:50 »
Hi,
I currently have mx clears, which I love, but I can only type on it for short stints — I'm a heavy-handed typist, and can't seem to get the hang of typing without bottoming out. I need a lighter mx switch, but the high-pitched click of blues drives me nuts.
I have an mx switch tester. If I  press the mx brown slowly, I can feel its tactile bump, but if I press it with any speed, as I would while typing, it feels identical to mx red. Is this just a false impression due to it being a tester and not a full board, or is it an accurate assessment of mx browns? Few shops in my area stock mechanical boards, and those that do don't bother to put out a display model, yet will not let you briefly open a box to try it for 20 seconds.
If I possessed physical dexterity I'd explore modding to ergo clears.
Offline cryptokey
  • [°°▄°] luser-friendly
Re: Typing on mx browns: indistinguishable from mx reds?
« Reply #1 on: Thu, 26 November 2015, 23:04:09 »
I'm on browns right now and you can definitely feel the tactile bump - though not as much as the clears.
[WTB] HHKB Black
Offline macguy80
« Reply #2 on: Thu, 26 November 2015, 23:07:04 »
Good to know. I was worried they'd be just like reds, since they are weighted the same. Thanks!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Fri, 27 November 2015, 01:26:32 »
The tactility in Cherry switches is very weak because it is generated in a rather primitive way. It sounds to me like you'd need to find some Monterey switches ;) .
Offline macguy80
« Reply #4 on: Fri, 27 November 2015, 01:32:19 »
Thanks for the suggestion! :) I must admit, they never crossed my mind! Those are found only in vintage boards, correct? I would need a modern layout, either 104 or 87 TKL. 101 would limit usability on a Mac, even with adapters.
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Fri, 27 November 2015, 02:12:11 »
The Oracle has spoken; you need a Chicony KB-5981. Check out my video review of mine:
Offline macguy80
« Reply #6 on: Fri, 27 November 2015, 03:05:53 »
Thank you! That looks and sounds awesome! I'll keep my eyes out for one!
Offline mikes41720
    • Ranting & Rambling
« Reply #7 on: Fri, 27 November 2015, 03:16:43 »
If you're looking for something more current and are looking for boards where you can feel tactility, try Matias Alps boards. The clicky and quiet switches are very tactile, I've heard.
« Reply #8 on: Fri, 27 November 2015, 03:21:03 »
Many say that browns feel like gritty reds.
Anyway, what's wrong with bottoming out all the time?
Offline macguy80
« Reply #9 on: Fri, 27 November 2015, 03:21:45 »
Actually, I have also been considering the Matias Tactile Pro 4 with the clicky switches. Do you know how they compare with the blue Montereys, Thomas? I only have the Matias Quiet Click switches, which are dampened in sound as well as feel, though they are still quite tactile and enjoyable. I'm just looking for more sound :)
Offline macguy80
« Reply #10 on: Fri, 27 November 2015, 03:24:23 »
There's absolutely nothing wrong with bottoming out all the time. I quite enjoy it. But on a board with stock Clears, that can get tiring quickly. :)
« Reply #11 on: Fri, 27 November 2015, 03:27:05 »
Actually clears is about the only switch I don't bottom out on all the time.
Not through want of trying, I just seem to be able to actually type on them without bottoming out every keystroke.  Like I am on this SSK!
Offline macguy80
« Reply #12 on: Fri, 27 November 2015, 03:42:13 »
That's a feat I can't do on my Unicomp Model M! :)
« Reply #13 on: Fri, 27 November 2015, 04:11:48 »
I bottom out everything!  Except the occasional MX clear.
