Author Topic: The long journey of the WhiteFox  (Read 362383 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: The long journey of the WhiteFox
« Reply #600 on: Fri, 22 July 2016, 10:28:05 »
Offline Thumper_
  • Spend all my money.
« Reply #601 on: Fri, 22 July 2016, 10:28:41 »
Offline eeymiel
« Reply #602 on: Fri, 22 July 2016, 13:08:06 »
okay so posting this again :)
(special edition, not sure it will be made, but the case will be gold anodized)
Was hoping we would see this version now. Maybe next time?
Offline VereChi
« Reply #603 on: Fri, 22 July 2016, 13:35:37 »
phew new drop
so it seems...  :blank:
Do we have DCS midnight 50% discount this time?
I missed the first time. Really need midnight to cover my Whitefox  :thumb:
Offline decker
« Reply #604 on: Thu, 28 July 2016, 01:25:01 »
Hello,
Does anybody know where I could buy a Azerty key set for the white fox ?
Ideally that look the same so I can keep the fox keys ?
Thanks
Offline Brammm87
« Reply #605 on: Thu, 28 July 2016, 07:21:16 »
Hello,
Thanks
As far as I know, Azerty isn't supported by the international expansion because it's not used enough to ever meet MOQs (I was in the same boat with Belgian Azerty). Switch to Qwerty and use the international layout, I can type anything I want in French :p
pls gief bbv2
Offline ac2531
« Reply #606 on: Tue, 02 August 2016, 10:35:51 »
I wasn't able to get in on the first drop, but I've got a TrueFox with Gat Browns on the way. This is my first mech build and I"m incredibly excited.
Thanks for all the effort you put in to this board, Matt3o. It's a beauty.
HHKB Pro 2 Type-S | HHKB Pro 1 | Realforce 87U (45g uniform) | WhiteFox (Gat Browns) | Anne Pro (Gat Reds) | WASD CODE (MX Clears)
Offline ideus
  • Björkö.
« Reply #607 on: Tue, 02 August 2016, 11:04:06 »
Hello,
Thanks
You can always use the alphas of an original Azerty key set, along with the modifiers of the Fox, or any other alternative key set that matches its modifiers.
Offline decker
« Reply #608 on: Tue, 02 August 2016, 16:18:39 »
Hi I've been directed by eksuen to WASD : 88-key-iso-cherry-mx-keycap-set
I should be able to get an Azerty cherry mx set of keys from them.
I believe the oly key that is fox specific is the right shift...
Thanks for the reply.
« Last Edit: Tue, 02 August 2016, 16:27:48 by decker »
Offline ideus
  • Björkö.
« Reply #609 on: Tue, 02 August 2016, 16:36:02 »
I am afraid those key caps are too cheap to be considered, their only advantage is that you can get them printed as you wish, I can make some pictures comparing some of them with OG Cherry and Granite as reference; but, believe me when I say that you'd better save some money and invest in a good set instead.
Offline decker
« Reply #610 on: Tue, 02 August 2016, 16:52:44 »
Arg !
What do you have in mind ?
Where can I buy good quality cherry mx caps and have them in Azerty ?
I don't think I'll join the drop that ends in 5 days if I dont have a clear view regarding the Azerty caps solution.
Offline eksuen
  • Ambassador of explosions.
« Reply #611 on: Tue, 02 August 2016, 17:31:44 »
Arg !
Yeah, they aren't the highest quality and will not last you as long as double-shots or dyesubs, but that's the tradeoff to get a completely custom layout printed. You'll have a hard time finding a "good set" with Azerty layout.
EDIT: My other suggestion was to get a set in DSA and swap the alphas to Azerty. The keys for symbols and punctuation may not all match, but at least it will get you part of the way there.
« Last Edit: Tue, 02 August 2016, 17:34:42 by eksuen »
Offline ideus
  • Björkö.
« Reply #612 on: Tue, 02 August 2016, 18:10:06 »
Arg !
If you are not already a DT member, I suggest you to join that board, from time to time, there are Azerty sets or keyboard for sale, most of the used sets are double shots, while they are not new and may have some shine they are always superior to those thin key caps. It is your call though; but, based on my own experience, I'd bet you will regret to get them, but be my guess, do not believe me, try for yourself, who knows, maybe you like them.
Offline HeroXLazer
« Reply #613 on: Fri, 10 March 2017, 18:36:37 »
Wait, so does the plate support switch-top removal?
Offline user 18
« Reply #614 on: Mon, 13 March 2017, 16:00:25 »
Mine from the first run appears to.
Avatar by ashdenej
Offline ac2531
« Reply #615 on: Tue, 11 April 2017, 13:00:58 »
Can confirm, the R2 WhiteFox allows for switchtop removal.
Offline leech
  • …always on the lookout for higher quality…
« Reply #616 on: Sat, 29 April 2017, 04:37:23 »
new be here. sorry for asking what is 'switchtop removal' and what is the average pricepoint of WhiteFox?
Does the WhiteFox support full RGB lighting through hardware and firmware?
Offline krisst
« Reply #617 on: Sat, 29 April 2017, 05:21:35 »
Switchtip removal in general means that the plate of the keyboard have these notches, for easy removal of MX switch top cover without desoldering the whole switch. This will aid easy maintenance and troubleshooting.
Average price for brand new Whitefox from Massdrop, would be around 180 usd. Depending on what type of switches and add-on you choose, prices varies.
Currently Whitefox does not support Full RGB out of the box, unless you would like to diy mod it yourself.
Some FAQs of Whitefox can be found here. http://matt3o.com/whitefox-faq/
Offline leech
« Reply #618 on: Sat, 29 April 2017, 05:36:44 »
Ahh now i get it, thanks for the explanation. It means that one could disassemble the switch and, for example, exchange the inside spring, while the bottom switch half remains soldered to the PCB. I was thinking that every mount plate is or should be constructed that way.
180$ is the lowest a buyer must invest?
While this special mkb/project might be worth this kind of money, it is too much for my portemonnaie. i love my mkb and all but i don't want to be overdoing it. It is crazy enough imho that i am looking at replacement switches on Aliexpress omg.
Thanks again for the answers, i am probably out of this thread from here on  :rolleyes:
Offline ddot
  • Master of Suspense
Offline chuckdee
Offline Marutks
« Reply #621 on: Mon, 26 June 2017, 18:09:36 »
I would like to join Whitefox kickstarter.  I am not sure about switches. I prefer tactile switches (Zealios 65g and 67g, MOD-Ms).   Are Halo switches similar?
Offline leech
« Reply #622 on: Sun, 08 April 2018, 07:44:56 »
A 4 years long adventure in search of the perfect 65%
The op was composed in Q4/2015. Minus the quoted 4 years … so the long search journey started in 2011, is that correct?
Time flies, we're in Q2/2018 now!
So how's the keeb holding up, everybody satisfied with the product, quality, performance, etc? It uses CherryMX switches, right? Why not use higher quality switches as reviewed by YouTube?
Offline eeymiel
« Reply #623 on: Sun, 15 April 2018, 12:12:44 »
Yeah I'm still very satisfied with my WhiteFox after almost 2 years. Still use it as my main keyboard, and recently bought a Nightfox, so I can leave one at my workplace. The NightFox (and probably newer WhiteFox) now has a USB-C connection and comes with cherry stabilizers, 2 welcome improvements on an already very good keyboard.
« Last Edit: Sun, 15 April 2018, 12:22:54 by eeymiel »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #624 on: Mon, 16 April 2018, 12:48:18 »
can't say cherry stabs is an improvement but a necessary evil :P
Offline Brammm87
« Reply #625 on: Wed, 18 April 2018, 02:22:07 »
If there's one thing I really dislike about my whitefox, it's the stabs that came with it. Every time I transported it, at least two came loose. It's currently in pieces waiting to be reassembled :p
pls gief bbv2
