Author Topic: 60% layout issues  (Read 5506 times)
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
60% layout issues
« on: Fri, 27 November 2015, 21:09:43 »
so ive built a keyboard using the GH60 TMK firmware. all the default settings everything works except for 2 keys on row 3 seem to be shifted. not sure whats going on any help would be great.
here is the keymap
     * |`| 1| 2| 3| 4| 5| 6=| 7| 8| 9|0|-|6=|BKSP|
     * |TAB|q| w|e|r|t|y]|u|i|o|p|[]|[]|y]\|
     * |caps|a|s|d|f|g|h|j|k|l|;|'|enter|
     * |shift|  |z|x|c|   |b|n|m|,|.|shift|
     * |ctrl|super|alt|         space            |alt|super|menu|???|
Projects
Offline deductivemonkee
  • Professional Lurker
Re: 60% layout issues
« Reply #1 on: Fri, 27 November 2015, 21:30:44 »
Hasu would know, but this should be in the tmk firmeware thread, where hasu will see it.
Sorry I cant help.
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Offline mrbishop
  • Evil Genius
« Reply #2 on: Fri, 27 November 2015, 22:00:54 »
Maybe I can move it or a mod can thanks for the direction to the correct thread. Oh I put caps on while I wait for help lol
Projects
« Reply #3 on: Fri, 27 November 2015, 22:03:39 »
I have to say, it looks great!
Offline mrbishop
  • Evil Genius
« Reply #4 on: Fri, 27 November 2015, 22:13:45 »
Projects
Offline neverused
« Reply #5 on: Sat, 28 November 2015, 00:55:27 »
I was looking at keymap_common.h and it looks like keymap_ansi follows the behavior that you mention. Are you actually using that code or is it a carry over from the old gh60 code?
Offline mrbishop
  • Evil Genius
« Reply #6 on: Sat, 28 November 2015, 00:56:08 »
Just the GH60
Projects
Offline mrbishop
  • Evil Genius
« Reply #7 on: Sat, 28 November 2015, 01:04:27 »
Was running the poker version
Projects
Offline neverused
« Reply #8 on: Sat, 28 November 2015, 01:34:05 »
Yes but within that keymap_poker and keymap_common.h there is reference to keymap_ansi which is called by a function layer I believe.
Offline mrbishop
  • Evil Genius
« Reply #9 on: Sat, 28 November 2015, 08:02:29 »
I haven't quite figured out how the firmware works so it's likely I just screwed something up
Projects
Offline Charger
« Reply #10 on: Sat, 28 November 2015, 08:48:29 »
there is a walk through on deskthority that i tend to look back on every few times when I mess  something up lol
http://deskthority.net/workshop-f7/how-to-build-your-very-own-keyboard-firmware-t7177.html
Offline mrbishop
  • Evil Genius
« Reply #11 on: Sat, 28 November 2015, 13:01:13 »
Just the GH60
so being a total noob to modifying the firmware what would you suggest. i'm looking at the common.h under the ansi table and i noticed there is no comma inbetween some of the values in the matrix could that cause the keys to be moved over to the next row/column?
/* ANSI valiant. No extra keys for ISO */
#define KEYMAP_ANSI( \
    K00, K01, K02, K03, K04, K05, K06, K07, K08, K09, K0A, K0B, K0C, K0D, \
    K10, K11, K12, K13, K14, K15, K16, K17, K18, K19, K1A, K1B, K1C, K1D, \
    K20, K21, K22, K23, K24, K25, K26, K27, K28, K29, K2A, K2B,      K2D, \
    K30, K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B, HERE    K3D, \
    K40, K41, K42,           K45,                     K4A, K4B, K4C, K4D  \
Projects
Offline nephiel
« Reply #12 on: Sun, 29 November 2015, 03:57:22 »
I don't see anything wrong there, on ANSI shift keys are wider than CapsLock and Enter, so this row has one key less than the row above.
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
Offline mrbishop
  • Evil Genius
« Reply #13 on: Sun, 29 November 2015, 13:13:49 »
got it working. turns out there were some hardware issues i wasn't aware of and needed to put my eyes on again. thanks to Suicidal_orange for all the time and help getting me to look more closely at my build. ready for tuning this one and working on future builds 40% and full 114key monster as well as LED back lit ones and pcb creation!
Projects
Offline ideus
  • Björkö.
« Reply #14 on: Sun, 29 November 2015, 22:46:02 »
Nice job.
