Author Topic: Asus RoG Gladius or Roccat Kone XTD Optical?  (Read 5583 times)
Offline Boozebreath
« on: Sat, 28 November 2015, 19:55:41 »
Need a new mouse since my current one is too small but I am having a hard time deciding between these two mice.  Both seem like solid choices which makes it even harder to decide.  Currently I am using the Logitech G502 but due to it's size it causes me wrist pain after an hour or two of use, mainly when playing FPS games.  Looked around and figured the Asus Gladius and Roccat Kone XTD Optical would be the best fit for my hand size.  I have large hands and I tend to use both fingertip and palm grips.  Mostly going to use it for FPS and MOBA/RTS games.  Might end up getting both but can only choose one for now and that decision is at a stalemate.
If you have used either one of these mice your input would be appreciated, thanks in advance.
Offline davkol
  •  Post Editing Timeout
Re: Asus RoG Gladius or Roccat Kone XTD Optical?
« Reply #1 on: Sun, 29 November 2015, 05:53:32 »
Isn't that kind of natural, that you're getting strained from continuous stress of such timespan?
