Author Topic: Model M2 Springs  (Read 2720 times)
Offline MFGorilla
Model M2 Springs
« on: Tue, 17 November 2009, 21:19:22 »
I got an IBM model M2 from Ebay a few months ago and finally got around to testing and cleaning it.  Luckily the keyboard (mostly) works and the electronics are fine.  Several of the keys don't "click" and on further investigation I found that the springs on the keys that don't click are bent, and therefore don't register.
Does the M2 use the same springs as the Model M?
Where can I buy some springs from?
How do I replace the springs?
Thanks in advance!
"I want an Official Red Ryder Carbine-Action Two-Hundred-Shot Range Model Air Rifle!"
Using Now: Unicomp Spacesaver (black/grey) | IBM Model M 1391401 White Label| IBM Model M 1394946 by Lexmark
[COMMENT]On The Way: IBM Model M Industrial[/COMMENT]
Wish list: Filco Majestouch tenless with Blue Cherries | Matias Tactile Pro 3 | IBM Model M Space Saver
In Storage: IBM M2, DELL bluetooth wireless
Offline itlnstln
Model M2 Springs
« Reply #1 on: Wed, 18 November 2009, 08:07:56 »
You can get the springs from Unicomp.  I am pretty worthless on the rest.
In fact, I'm pretty worthless, in general.
Offline Mercen_505
Model M2 Springs
« Reply #2 on: Wed, 18 November 2009, 08:23:27 »
Model M2 and M use the same springs, so you can get some from Unicomp or Clickykeyboards or wherever you please. Some people possess the necessary dexterity to successfully pull and seat a new spring without having to crack the case -- I certainly do not :(
Aside from the many plastic clasps you can see on the back of the keyboard, the M2 is surprisingly easy to break down. It's a bit of a pain to reassemble. Try to keep it upside down when you take it apart, so the springs don't fall out as soon as you crack the case.
Offline lowpoly
Model M2 Springs
« Reply #3 on: Wed, 18 November 2009, 10:45:49 »
And take a pic, there are more holes than springs.
Offline iMav
  • geekhack creator/founder
Model M2 Springs
« Reply #4 on: Thu, 19 November 2009, 23:25:32 »
I have a M2 that I replaced ALL the BS assemblies on.  Got them from Unicomp.
Offline kyamei
Model M2 Springs
« Reply #5 on: Thu, 19 November 2009, 23:38:57 »
About how much does Unicomp charge for a full set of springs?  I have a working M2 that has a several bent springs (keys still click and register though) that I might decide to fix up.
Topre:  Realforce 101, Realforce 87U, HHKB Pro 2
Cherry Brown:  Compaq MX11800
Cherry Blue:  Filco FKBN87MC/EB
Cherry Black:  K-202 numerical keypad
Alps Black:  AT101W, ABS M1
Alps White:  Focus FK-2001
Buckling Springs:  Model M 1391401, Lexmark Model M 82G2383, Model M2
Buckling Sleeves:  Unicomp Model M4
Futaba:  Sejin EAT-1010
