Author Topic: Ninja (front print) Keycap for Mac usage?  (Read 2827 times)
Offline cccid
« on: Mon, 30 November 2015, 20:25:02 »
Hi there, first time posting here..
just dived into the mechanical keyboard scene recently. after a lot of research and lurking on here and reddit, i decided to go for the 10keyless ninja wilco /w brown switch. Loving it so far.  ;D ;D ;D
As i was searching some options to upgrade my keycaps, while trying to keep my ninja (front printed) look. I couldn't find any keycaps with Mac function/media keys being front printed.  Are they really non-existent or i just haven't found them yet?
thanks in advance! (this is a awesome community btw!)  ;D
Offline zombimuncha
Re: Ninja (front print) Keycap for Mac usage?
« Reply #1 on: Tue, 01 December 2015, 00:39:59 »
If you get light-coloured blanks you can add your own darker-coloured front legends using water-slide transfer paper.
