Author Topic: I recorded my HHKB before and after lubing  (Read 1749 times)
Offline vegs
« on: Tue, 01 December 2015, 16:26:15 »
Here's two recordings of my HHKB Pro 2 45g with dental bands - before and after lubing. I used the EK MechLube 2.
No lube.
With lube.
As you can hear the sound isn't all that different. I've yet to "break in" the lube, but it feels pretty good. Removes a little bit of the snappiness, but makes it quiter and a bit smoother.
Sorry for the background noise. Didn't realize it was there until I was recording my second clip, and wanted to keep the recordings as similar as possible.
« Last Edit: Tue, 01 December 2015, 16:28:23 by Veggis »
hhkb 4 life
buy less
Offline Altis
Re: I recorded my HHKB before and after lubing
« Reply #1 on: Tue, 01 December 2015, 18:10:13 »
Still sounds gritty. I find the Realforce 87U to be quite a bit smoother than my HHKB.
I've been meaning to lube my HHKB and will probably get around to it this week and see how it is, as well as add sound deadening inside the case.
Thanks for sharing!
Offline Coreda
« Reply #2 on: Tue, 01 December 2015, 18:57:25 »
lewd
Offline raymogi
« Reply #3 on: Tue, 01 December 2015, 19:02:41 »
Yea I don't think lubing is gonna change the sound a lot but it surely will make it feel smoother.
Please feed my addiction.
Offline Latin00032
« Reply #4 on: Tue, 01 December 2015, 19:32:21 »
Where do I get dental bands?
Is there a certain size I should get?
Offline mikes41720
    • Ranting & Rambling
« Reply #5 on: Tue, 01 December 2015, 21:18:23 »
Was it worth it?
Offline phruitpie
« Reply #6 on: Tue, 01 December 2015, 21:26:02 »
I think most people go for either 3/16" or 1/8" bands, ebay is prob the best place to pick some up.
